The MP3car.com Store
Thread Tools Display Modes
Old 04-28-2005, 07:47 AM   #1
tbird2340's CarPC Specs
tbird2340's Avatar
Vehicle: 2005 Dodge Ram Quad Cab
My Photos: (0)
Sound from Carputer sometimes bad, from CD it's not?
Ok. I have a CD player w/ AUX in that my carputer goes into. Sometimes when I'm listening to music through my carputer the sound is kinda crappy. It's hard to explain but it's only certain ranges of sound that sound like jack.
I thought it was my speakers but I did a test. I put in an Evanescense CD and also have that CD on mp3 on my carputer. I switched back and forth from AUX to CD while the songs were playing to see if they both sounded the same and the CD doesn't have the static sound that my carputer does.
What could cause this? Soundcard? I'm using the onboard sound of my M10000.
Thanks for any help.
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Sponsored Links
Old 04-28-2005, 07:51 AM   #2
elmo's Avatar
Vehicle: 03 Renault Laguna
My Photos: (0)
Not sure if anyone will disagree with me but i wouldnt recommend using onboard anything as they arent meant to be as robust or powerfull as the PCI equivelents. So for the first step... even if this doesnt solve the static problem... get a new sound card
www.streetrace.co.uk - The UK's best modified car club (With lots of 16/17/18 year olds for scouse to abuse)
elmo is offline   Reply With Quote
Old 04-28-2005, 07:59 AM   #3
tbird2340's Avatar
My Photos: (0)
Thanks for the reply. You talking USB? I dunno if I could fit a PCI in my case.. What do you recommend?
Old 04-29-2005, 10:30 AM   #4
tbird2340's Avatar
My Photos: (0)
Bump
Old 04-29-2005, 10:35 AM   #5
Top Ramen
lgbr's Avatar
Vehicle: 1991 Toyota MR2 Turbo
My Photos: (0)
He's probably right. Get a USB.
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
Quote:
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
lgbr is offline   Reply With Quote
Old 04-29-2005, 10:42 AM   #6
tbird2340's Avatar
My Photos: (0)
Suggestions?
Old 04-29-2005, 10:57 AM   #7
My Photos: (0)
I have the Same exact problem, i think it is the soundcard cuz i tried my brothers computer and it worked like a dream, i have a temporary fix,
1. Turn the volume on ur computer down and when u turn up the headunit theres no static. <--- worked for me
2. try to get a new soundcard, my friend is gonna let me borrow his audigy this weekend ill let you know if it solves the problem.
let me know if u make any progress
dave
2001 Lexus IS300
P4 2.4GHz(completed and configured!)
Tview 700TS
working on trunk fabrication for computer box
[ ||||||||||||||||||-- ] 95% done
Zshopa is offline   Reply With Quote
Old 04-29-2005, 12:19 PM   #8
Willy-Mach1's CarPC Specs
Willy-Mach1's Avatar
Vehicle: 2003 Ford Mustang Mach1
My Photos: (0)
The Audigy USB is nice. There is also a USB Sound Blaster Live 5.1 (which I have)....the Live! is cheaper and does (as far as I can tell) the same job as the Audigy as far as audio playback, plus you'll save some $$$ which is always good!!!!
Progress: |##########| 99.99%
- Tweaking and enjoying!!!! Never really done.....
-= MachPuter Project =-
-= MachPuter Project Worklog=-
Willy-Mach1 is offline   Reply With Quote
Old 04-29-2005, 07:41 PM   #9
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
i wonder if it's just the mp3 compression that you are noticing
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 05-02-2005, 02:59 PM   #10
tbird2340's Avatar
My Photos: (0)
@scott_fx, no.. I don't think it's the compression. To test I burned a set of MP3's as an audio CD and then listened to those same MP3's from my carputer. The crappy sound didn't happen from my deck but did happen on the carputer.
@Willy-Mach1, so you like the USB Live!? How much did you pay for it?
@Zshopa, did you try your friend's audigy?
Sponsored Links
Old 05-03-2005, 09:01 AM   #11
sdashiki's Avatar
Vehicle: 2003/Toyota/Matrix
My Photos: (0)
change your RCA cables, cheap ones are just that, cheap. Dont buy $$$ RCAs, but try switching first, or twisting the connections, if that makes a noise,its the wires or the connectors.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 05-03-2005, 09:09 AM   #12
tbird2340's Avatar
My Photos: (0)
Well the problem is I have to go from a LINE IN jack to RCA's. Do they make a high end cable like that? I have this coming from my head unit:
Connecting up to this going to my sound card:
Old 05-03-2005, 09:10 AM   #13
sdashiki's Avatar
My Photos: (0)
damn, yer head unit is an oldie eh? or at least el cheapo
sounds like anyone of the cables could be the culprit, jiggle and switch and see if it makes any sound.
(----) 0.0%
Old 05-03-2005, 09:17 AM   #14
tbird2340's Avatar
My Photos: (0)
Yes. It was elcheapo ($100). Why would I buy an uber expensive deck when I'm only using it for volume control (when you think about it).. This is the deck.
I didn't think it would have a lot to do w/ the SQ.
Old 05-03-2005, 09:23 AM   #15
My Photos: (0)
@tbird....I really like my Soundblaster USB Live! I paid around $50 for it and it works like a charm!
Sponsored Links
vB code is On
Trackbacks are Off
Basic Carputer Question septicdeath Software & Software Development 2 09-23-2004 12:51 PM
Auto power off accord General Hardware Discussion 29 08-15-2004 07:08 AM
Sound quality not as good as CD.. BootySlap General Hardware Discussion 17 10-30-2001 10:47 PM
Need advice on which sound card to use mtmsol General Hardware Discussion 2 06-22-2001 12:39 PM
Does this sound like a bad tape? BLACKOUT General Hardware Discussion 3 03-28-2001 09:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
