Old 06-01-2005, 08:04 PM   #1
modh1984 is on a distinguished road
amp temperature
i was wondering what the average temperature was for most people on there amp is. the temperture in my car was about 70 degree Farneheit. I had my amp on for about 20 min and the the temp on the amp was 130F and the internal fan on the amp didnt turn on... i have an alpine mrv-f345. I am afraid that the fan might not be working and i just bought the amp so i can still replace it. should i been concerned?? i know that the amp will turn off automatically if the temperature gets to hot but i was just wondering before that might happen.
modh1984 is offline   Reply With Quote
Old 06-01-2005, 08:19 PM   #2
Jahntassa's Avatar
Jahntassa is on a distinguished road
Unless you're having problems I wouldn't worry too much about it. How do you know what the temp was on the amp? Was it on the heatsink, or is there an internal temp meter? If it's brand new, I wouldn't be too concerned. Otherwise, try calling Alpine and ask them what the temperature tolerances are.
Jahntassa is offline   Reply With Quote
Old 06-01-2005, 08:24 PM   #3
Quote: Originally Posted by Jahntassa
...Was it on the heatsink, or is there an internal temp meter? ....
There is an internal temp meter on the amp
Old 06-03-2005, 09:44 AM   #4
xtraxmechx is on a distinguished road
I've had some amps that i think i could have cooked a steak on.
xtraxmechx is offline   Reply With Quote
Old 06-03-2005, 09:50 AM   #5
neon_eddy's Avatar
neon_eddy is on a distinguished road
mmmm.. steak
you could ahve different tracks with different current draw at a set volume for different cooking tempertures..
"anyone seen my medium high CD?"
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
neon_eddy is offline   Reply With Quote
Old 06-08-2005, 08:58 PM   #6
today it was 90 degrees outside and the amp got the 170 F, the fan on the amp still did not turn on
Old 06-08-2005, 09:06 PM   #7
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
It is New Change it and compere the temp. with the one that you return.
thanatos106 is offline   Reply With Quote
Old 06-08-2005, 10:03 PM   #8
mbuchman's Avatar
mbuchman is on a distinguished road
I would think you have a problem. I know for my amps, they have no fans or anything, just one giant heatsink, and none of them got hot even though I was giving them all I could handle (my goal was to overheat them, I failed.) But then again, each one of thsoe amps weighs 20 pounds, so like I said, huge heatsink...
170 just seems really hot for an amp, so I would contact Alpine or something. Or, just run it at high power for a long time to try to overheat it.
Matt
mbuchman is offline   Reply With Quote
Old 06-08-2005, 11:12 PM   #9
Jahntassa's Avatar
Depends on where the temperature sensor is. If it's on the amplifiers itself, then, yeah, it could probably easily get that high...
Old 06-08-2005, 11:18 PM   #10
binary.h4x's Avatar
binary.h4x
have you tried searching to see at what temp the fan is supposed to turn on?
binary.h4x is offline   Reply With Quote
Old 06-09-2005, 11:12 PM   #11
I need to call Alpine, last time I called, I was on hold for like 30 min and I just said screw it... may be were closed at the time I called, who knows.
Old 06-10-2005, 09:20 AM   #12
binary.h4x's Avatar
binary.h4x
yeah, hold sucks
Old 06-12-2005, 09:19 PM   #13
-zip-'s Avatar
-zip- is on a distinguished road
Does the amp have thermal protection? If it does, dont worry about it, if things get to hot to handle it will shut down.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 06-13-2005, 11:24 PM   #14
yea it does.
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
Car Audio People, Help me pick an amp / Jeep GC w/ Infinety System hevnsnt Car Audio 3 12-07-2004 07:34 PM
People with NO HeadUnit, Recommand AMP!! camsgs3 Newbie 30 07-26-2004 07:38 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
