watts = amps * volts. So, if you maxed out that amplifier, you'd only need 50/14.4 (I have no idea what that 10 volts was all about, charging voltage is 14.4 in a 12 volt car system). So a 3.5 amp fuse would be enough. You primarily want to protect against short circuits as that sony amp is essentially disposable. When you get your Rock back, you're looking at 34 amps. a 40 watt fuse is perfect! However, I'd stop by Napa or Pep Boys and get a bus fuse. I don't trust anything from Walmart.
