Old 06-07-2005, 08:17 PM   #1
How are you guys amping your center channel for 5.1?
Hi there,
As my dash LCD install progresses well, I'm getting everything together for my sound system overhaul.
I will be doing a full 5.1 setup, and I was wondering what other 5.1 setups used as a center channel amp. Dur to space restrictions, my center channel will be a 3.5" coaxial fullrange speaker, rated at 40W RMS.
There's really no such thing as a 40W mono amp, and even the smallest amp I have (Rockford Punch 100a2) is too much for this speaker in bridged mode. I could use only one of the two channels on that amp, that that feels like a waste to me...
Just curious to know what solutions there were out there.
Luc
Sentra CarPuter:
-InnovaTek 7" LCD touchscreen, Biostar M7VIZ w/ AMD Athlon XP-M @800 MHz 1.1V, 512 RAM, 160G HDD, M-Audio Revolution 5.1, USB Wi-Fi with custom external antenna, Holux GPS and lots of really nice audio bits...
RFMan is offline   Reply With Quote
Old 06-08-2005, 03:02 AM   #2
Jesus Freak
antimatter's Avatar
I bought a 6 channel amp (soundstream D'artagan)
antimatter is offline   Reply With Quote
Old 06-08-2005, 11:16 AM   #3
I'd get a 5-channel amp for the surround speakers, and then a big mono amp (or bridged 2-channel) for the subs. I'm pretty sure most manufacturers make a 5-channel amp, though I know Alpine does for sure.
WxGuy1 is offline   Reply With Quote
Old 06-08-2005, 11:20 AM   #4
sdashiki's Avatar
most 5 channel amps, I think, the 5th channel is a MONO channel for subs, if it has a Full Range switch for it, awesome. But my Rockford 600.5 only lets me set it at 120hz/80/50
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 06-08-2005, 11:27 AM   #5
I am using a Clarion SRK5 1/2-DIN Center Channel Speaker for my center channel.
billforde is offline   Reply With Quote
Old 06-08-2005, 11:37 AM   #6
sdashiki's Avatar
Id put that above the rearview mirror (like where there is either map lights, sunroof controls, sunglass holders) inside the DIN space is kinda ugly, and wat if you spill or splash some liquid on it....ewwww
(----) 0.0%
Old 06-08-2005, 06:25 PM   #7
My problem is not that I'm running out of amp channels (I have a Zapco AG-650 6-channel, and a RF Punch 100.2 also available, not to mention my old-school MTX D class cheater monoblock. My problem is that all those amps put out too much power for that speaker, escept if I use only 1 of the 2 channels on the RF (which is probably what I might end up doing)
BTW, my nickname does not come from Rockford Fosgate, I got it because I'm a Radio Frequency Engineer.
Sentra CarPuter:
Old 06-08-2005, 06:37 PM   #8
RF engineering is scary! I'm glad there are people like you to do the scary black magic work.
Rickertsen2 is offline   Reply With Quote
Old 06-09-2005, 12:53 PM   #9
That's what keeps the work interesting!
Sentra CarPuter:
Old 06-25-2005, 07:47 PM   #10
if you can get your hands on an old Jensen XA92 its a small 2 ch 88 watt max amp that you can bridge the outputs
pancit175 is offline   Reply With Quote
Old 06-26-2005, 11:53 PM   #11
I'm running a 4channel diamond, 2channels for my tweeters, 3rd channel for the center, the 4th will go unused
Now, if you wanna go the Car pC route, this is the right forum for you. You can surf gay porn, listen to all your copywright infringed music and use GPS to find your way from one end of the driveway to the other -J187
yak8998 is offline   Reply With Quote
Old 06-27-2005, 09:21 AM   #12
Raw Wave
Defiler's Avatar
Alpine offers a few setups for 5/6 channels. The MRA-D550: 5 Ch. 60Wx5, MRA-F350 5Ch. 50Wx5, or two MRV-F345s. The 345s set up in 3 Ch. mode will give you the full 5.1 setup. on the first amp bridge ch. 1 and 2 to give 75W for your center. Then the other two Ch. will give 75W each for your front L and R. On the other amp Ch. 1 and 2 will give you 75W for your rear L and R and Bridge Ch. 3 and 4 to give 300W for the sub.
I'll be going the F345 route.
/////Alpine PXA-H700
/////Alpine MRV-F345
Aura MR62 (F and R)
Sansa Clip
All wires by Knukonceptz.
My Current MP3s
IamDefiler.com
Still have tons of parts for sale!!!
Looking to sell my Alpine PXA-H700 setup
Defiler is offline   Reply With Quote
neocar media center EN version, here it is :) netsuo NeoCar Media Center 34 10-04-2004 12:36 PM
good question about center channel speakers mengela General Hardware Discussion 7 10-04-2004 04:13 AM
Audio / Carputer Hook Up? reece146 Car Audio 8 09-15-2004 12:57 PM
The BEST and EASIEST way to add CENTER CHANNEL to your car !!!! lookinco Car Audio 8 09-01-2004 01:54 PM
WRX owners. Clock or Boost Pod Gauge area. Center channel Speaker. LESLIEx317537 General Hardware Discussion 5 04-02-2004 04:37 PM
