Old 06-23-2005, 11:01 AM   #1
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Red face Extension cable for Honda HU connectors?
I am trying to relocate my Head unit to a lower position on my dash. (Honda CR-V). The problem is that the stock cable is not long enough!!!
Is there some sort of extension I can buy, to add another feet or two? I am envisioning a cable going from male to female, with the exact same pinouts that the OEM Honda HU connector has.
If this does not exist, what are my options?! how are you all relocating your headunits to a lower spot in your dashes ?
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Advertisement Sponsored links
Old 06-23-2005, 11:46 AM   #2
VTPCGeek is on a distinguished road
you could always do it the old fashioned way, splice the cable to make more length.
VTPCGeek is offline   Reply With Quote
Old 06-23-2005, 11:49 AM   #3
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
They probably have it but I am not sure. There is a connector that plug in to the car harness for after market radio. This one is easy as every place has them. There is also a connector for using stock radio in different car. This one is a PITA to find. I know they have one for Toyota (86-90 cars). When you find the 2, connect 'em together to make an extension.
Your other option is go to junkyard and get/cut/chop the "To-HU" end from the same car or different Honda (if it the same as yours). Now buy the "to-Harness" end and connect them together.
Another option is cut your car harness and make the wire longer, but I am sure you dont' want to do that.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-23-2005, 01:07 PM   #4
Raw Wave
justintime's Avatar
Thanks guys. Im trying to avoid cuttin the OEM harness. I think best option is to try to find the 2 connectors, and build an extension. (good luck with that LOL)
2002 Honda CR-V
Old 06-23-2005, 01:17 PM   #5
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
why you don't tap the cables???? so you don't need to cut.
thanatos106 is offline   Reply With Quote
Old 06-23-2005, 02:14 PM   #6
Raw Wave
justintime's Avatar
thanatos: can you elaborate? when you say tap, what exactly do you have in mind?
2002 Honda CR-V
Old 06-24-2005, 12:25 AM   #7
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
go to a car audio shop and get an aftermarket harness (that will give you the one half of the extension for between 12-20 dollars) then go th honda and get a connector for you stock radio (most likely around $40) then just add all the wire you need to make it long enough no cutting
Aron
Edit: sorry Matrix didnt see your post good idea though
boomintrac is offline   Reply With Quote
Old 06-24-2005, 12:41 AM   #8
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
hey my friend just extended it use networkign cable he ran his under his seat! lol
xdjxklusivex is offline   Reply With Quote
Old 06-24-2005, 09:14 PM   #9
Raw Wave
justintime's Avatar
OK guys, as it turns out, they sell both ends (both connector types) in eBay. I bought two, and will build an extension cable
Total cost under $20.
2002 Honda CR-V
FS: Hirose DF9M connectors (for creating a cable for the controllers) infrared Classified Archive 8 04-30-2003 11:49 PM
LCD extension cable ThinkPad 560 hakan LCD/Display 1 03-22-2002 08:36 AM
Can't get VGA extension cable to work... SuperMatty LCD/Display 2 01-14-2002 05:07 PM
printer extension cable blacktooth General Hardware Discussion 1 03-10-2001 03:57 PM
lcd cable length extension? newbie General Hardware Discussion 0 03-13-2000 06:31 PM
