Quote: Originally Posted by pancit175
Ultimately what i would recomend is to scrap the stock amps, and speakers and get new ones.
I agree with this part, but i think pancit needs to take a midol.
with the corvette bose system the front door location house the 8" subs and a 3.5" 'twiddler' and the rear has either a 5.25" or 6.5" speakers. the 3.5" and the rear speakers have no bose amp and can be driven by an amplifiier. the sub is what is amped and that is why we need the interface. I am not sure; because i've never used a soundgate adaptor, but if it can take low level inputs you may be able to wire the soundgate to the soundcard and then take advantage of the bose amps for the subs. Then you could get a small amp and power the non-amped speakers (if it is like a c5 corvette bose set up) keep in mind that the impedance of the bose speaker may be 1 or 2 ohms so make sure your amp can handle it. also they can't be driven that hard or they'll distort and fry. one solution would be to swap out the non amped speakers with some nice aftermarket ones (either before or after you fry them
) and keep the rest of the system 'stock' or rip out everything; like i did, and keep it clean with out a bose interface.
now i'm not an installer and this is pretty c5 specific, but if you research your setup you may be able to apply some of these methods to your own car.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
