FM mod works pretty good in our cars if you take your time and play with grounding it. I have an 03 envoy.
getting that center piece off is a total byatch. you have to remove the center consule, and that u-shaped carpet piece under the dash, theres 2 screws on the bottom of the dash piece.
BUT theres an easy way to do it, just grab the top vents and pull, the snaps will come out, the dash will bend out enough to get the radio out. ive only taken the piece off twice, its perfectly fine to just bend it back, never broken mine and i've done it a ton of times.
Now, if you wanna go the Car pC route, this is the right forum for you. You can surf gay porn, listen to all your copywright infringed music and use GPS to find your way from one end of the driveway to the other -J187
