Amps cut out and speakers make a bad pop noise.
The stereo specs
1. ID CXS6 2ohm....
http://www.cardomain.com/item/IDSCXS62
Recomended RMS 150w
Peak Power 300w
2. PG Xenon x200.2....
http://www.cardomain.com/item/PHOX2002
RMS 200wx2 @ 4ohms
3. IDQ10 D4.....
http://www.cardomain.com/item/IDSIDQ10D4V2
Recomended RMS 250w
Peak Power 500w
4. PG Octane R 5.0:1 Monoblock....
http://www.cardomain.com/item/PHOR501
RMS 300w @ 2ohms
5. PG Tantrum DD5 ......
http://www.cardomain.com/item/PHOTDD5
I have a 4g wire fused off the battery to a distribution block. The block has
1. 60amp fuse runin 4g to the xenon x200.2
2. 60amp fuse 8g to Octane R 5.0:1
3. 30amp fuse 8g to Tantrum DD5
I then have matching gauge grounds to another distro block which is then a 4g wire to groung under seat belt bolt.
Well first off is that i was completly retarded and didnt relize it untill everything was installed that the x200.2 was 200w RMS @4ohms and my components are 2ohm. So the amp then has 400w RMS @2ohms..Right?
Which is way to much power for the components.
PROBLEM.
1. when turning up the speakers the front left speaker would make a loud pop
noise. The amps and tantrum then power off and sometimes restart. Then
even at low volumes everything would power off.
MY THOUGHTS.
1. First thing I did was check all my speaker wiring. I have 14g going to
my components and 12g going to the sub. I found no shorts and wrapped
anything i thought could cause a problem.
2. Next I hooked up the equipment individually. I kept grounds as stated
earlier.
3. First I just powered the Xenon x200.2 to the components and set the
crossover to HP 117Hz and sensitivity (gain) all the way down.
At first everything seemed okay but with even moderate volume the
speaker would pop loud. I then used a little MTX 75wx2 rms amp to
power the speakers fearing that i was overpowering them. It was fine on
a HP filter with gain all the way down. On FP the speaker would pop again
which I believe is the speaker slapping the coil. But 75w rms should not
make these speakers bottom out, right?
4. Second powered up just the sub and had no real problems except that the
box wasnt air tight so it sounded like shiz.
5. Third hooked up the MTX 75w rms amp and the tantrum DD5. Everything
seemed ok and to be running fairly well. (this was with car parked)
then went for a drive, all is well then i pull into a parking spot and the
tantrum DD5 and MTX amp shut off, then restart. And sometimes it seems
like bumps cause it to shut off but sometimes it just clicks on and off.
Volume level does not matter, it happens at low and high volume.
QUESTIONS
1. Why is my speaker popping even when well underpowered. (pretty sure
there is no speaker wire short).
2. Why are my amps clipping out even at super low volumes?
I could use all the help I can get on this as I am stumped. (I think it is a ground issue).
PLZ PLZ help i am trying to leave on a trip by friday so I got to get this figured out.
Side note: I dont think the speaker is blown it read like 1.9ohms
Also I have pics if it would help.
Thanks,
