Old 06-30-2005, 03:10 PM   #1
jdogg1583 is on a distinguished road
audio noise and ground loop isolator
ok well just like many other people i have a noise coming through my speakers when im at high rpms. i went to radio shack and bought a ground loop isolator and installed. it totally gets rid of the noise, but it also completely takes out the bass. any ideas of how to fix either problem?
also, i have a mustang with the mach 460 stereo. does anyone know where the amps in the trunk are grounded? i looked all over and searched the web and i can't find anything.
any help would be awsome. thanks.
jdogg1583 is offline   Reply With Quote
Old 06-30-2005, 06:36 PM   #2
Drdee's Avatar
Drdee is on a distinguished road
Trouble with the isolator is its AC coupling your head-unit to the amp. Its possible before you used the isolator you were DC coupled. In any case even if you were not, your lowest cut-off frequency would have let the wanted low-frequencies pass through. Now in effect you have a high-pass filter. I'm surprised though that is removes all the bass. Perhaps try a different better quality isolator. Also it might be worth looking at the frequency responses of these devices before choosing a suitable one. They will have some roll-off at the lower end but should be below the audible hearing range, 30Hz or so.
Drdee
Drdee is offline   Reply With Quote
Old 06-30-2005, 07:28 PM   #3
neon_eddy's Avatar
neon_eddy is on a distinguished road
I made a good isolater from 2 mono channel isolators, and it was only about $7 to make and works great .. keep in mind they just lay a inverse of the noise over the original sou nd to remove noise, so if your bass gets cut out, you're getting bass freqency noise I would suspect.. or it's a sucky isolator.. I got my parts from RS too.. don't ever lsiten to the bone heads who work there and sell phones to people all day...
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
neon_eddy is offline   Reply With Quote
Old 06-30-2005, 08:13 PM   #4
pancit175 is on a distinguished road
did the ground loop isolator come equipt with a wire that you could ground to the chasis. With the ones that i've worked with, they say if less sound or no sound at all comes through there after using the gli, then you shoud ground those wires and it should work properly. If it doesnt come with that option i would suggest that you pick up one that you can ground.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 06-30-2005, 10:48 PM   #5
still lost
this is what i have:
http://www.radioshack.com/product.as...t%5Fid=270-054
no, it doesn't allow me to ground it anywhere. i really don't understand anything you are telling me. i don't understand audio at all. and someone explain it more to me? please. thanks.
Old 07-01-2005, 12:45 PM   #6
http://www.installedge.com/products/...roductID=14672
you can pick this up at bestbuy. GROUND LOOP ISOLATOR W/ "1.3 DB GAIN ON LOW END" so you dont get bass drain.
PROGRESS:
Old 07-01-2005, 11:34 PM   #7
Cheekz185 will become famous soon enough
Hey did you fix the problem? IF you did let me know what it was
Cheekz185 is offline   Reply With Quote
Old 07-02-2005, 02:16 AM   #8
no im still looking for a solution
Old 07-02-2005, 05:35 PM   #9
still isn't working
i picked up that gli from bestbuy that was recommended and it took the bass out too. anybody have any other suggestions? please let me know. thanks.
Old 07-02-2005, 09:04 PM   #10
did you try grounding the brown wires attached to it?
PROGRESS:
Old 07-03-2005, 10:59 AM   #11
no it said you are only supposed to do that if there is no sound what so ever
Old 07-03-2005, 11:42 AM   #12
scochran is on a distinguished road
You may want to look into 10-amp Noise Filter Catalog # 270-051 from radio shack. I am no expert by no means, but I had two noise problems, and this fixed one of them. After talking to electronics guru from radio shack he explained how what and why noise happens. The high rpms you mention is more then likely alternator noise. If you start your car, turn your stereo up, mute the sound or pause, now push on the accelerator while in park do you hear the noise? If so, you have alternator whine. I just added the 10-amp noise filter that powers the 7” touch screen, xm radio, and Head Unit now there is clear sound . This way it just filters the power and you do not loose your highs and lows. Like I said above I am no expert, this is just what info the radio shack, and a little reading gave me. This may or may not fix your problem but it is worth a try. Good luck!
My two power problems were~
1. Alternator whine coming in from the power to the 7” touch screen. This was back feeding into the vga cable going to the carputer then through the speakers. This caused the awful whine noise while accelerating. (The above fixed this problem)
2. Cheap power inverter is the other
Sam
scochran is offline   Reply With Quote
Inverter Question phatchink Power Supplies 27 08-21-2006 01:45 PM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 11:31 AM
Ground Loop Isolator Matthew230 Car Audio 7 10-28-2004 03:11 PM
Automotive electrical noise filter (not ground loop isolator) zPilott Power Supplies 2 10-28-2004 02:52 PM
ground loop isolator help digital chaos General Hardware Discussion 10 03-11-2001 02:38 AM
