Old 07-02-2005, 02:43 PM   #1
fluffy2097's Avatar
fluffy2097
headphone jack misery
So the headphone jack on my laptop broke off the other day, and now my system has no sound. I took the bastard apart completely (had to remove all but 5 screws) and imagine my surprise when I found 5 seperate pins inside instead of 3!
Not to be discouraged, I pressed on and soldered a new headphone jack to what I thought were the signal pins, and put the whole mess back together.
Still no sound, but I did get PC speaker beeps through the headphones. So i took it completely apart again and rewired. now I have no sound. So I have to take it apart again. Can anyone enlighten me as to how the heck to wire this thing properly? I'm about to just wire an ethernet cable to the mobo, and then try combinations until I hear something.
This is an old pentium 3 compaq laptop.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
fluffy2097 is offline   Reply With Quote
Old 07-03-2005, 03:09 AM   #2
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
If you still have the "broken" part, line it up to see which go to where.
Other than that, you have to get another similar laptop to open it out and see the pin.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 07-03-2005, 07:44 PM   #3
numbers's Avatar
numbers is on a distinguished road
You really need to find a jack like the one that came off. The extra contacts are used to cut the internal speakers when you plug something into the jack, and re-enable them when you remove it.
numbers is offline   Reply With Quote
Old 07-03-2005, 07:56 PM   #4
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
or just get a usb soundcard - much better for the carPC
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 07-04-2005, 07:31 AM   #5
techy101's Avatar
techy101 is on a distinguished road
the term for the type of connector is called "normalizing"
Hope that helps ya out a bit in your search.
techy101 is offline   Reply With Quote
ipod headphone out -> headunit dwillyson Car Audio 6 03-25-2005 08:28 AM
Laptop speakers output even with headphone jack in use ruairi Car Audio 3 03-09-2005 11:24 AM
could I connect a laptop headphone jack to a radio with an Aux in rca plug. Amax Car Audio 2 03-01-2005 06:23 PM
1/8 jack CD player/Amp? Is it possible? yellowfellow21 Car Audio 4 12-17-2004 11:42 PM
mobo audio jack sloppy cybermob2 General Hardware Discussion 0 05-12-2004 09:27 PM
