Old 07-05-2005, 07:00 PM   #1
c a m a r o is on a distinguished road
rca cables
I recieved my amp installation kit today. The rca cables have a small wire attached to them. What is it for? I'll post a picture if no one understands what I'm talking about.
c a m a r o is offline   Reply With Quote
Old 07-05-2005, 07:36 PM   #2
Cheekz185 will become famous soon enough
It carry's a remote signal (switched ignition, meaning your amps turn on when your Head Unit does). So you dont have to run an extra wire from your head unit to you amp.
Cheekz185 is offline   Reply With Quote
Old 07-05-2005, 08:36 PM   #3
so i have to splice it into the ignition wire that goes to the stereo?
Old 07-05-2005, 08:38 PM   #4
pancit175 is on a distinguished road
NEVER!?! That wire is too small of a gauge to run the remote wire from the hu to the amp. In some cases i've seen people attempt that and smoke the wire because the wire was too small and caused too much electrical friction.
The real reason for the extra wire is to ground the amp and the hu together so that it would decrease any ground differential between the two. Thus cancelling out ground looping noise.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 07-05-2005, 08:40 PM   #5
Mr. Wiggles
shakes's Avatar
shakes is on a distinguished road
what pancti said ...
you should use 14 or 16 guage wire for the trigger wire
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 07-05-2005, 09:07 PM   #6
mbuchman's Avatar
mbuchman is on a distinguished road
Haha, yeah, I used it as the remote turn on wire and it definately didnt work. A few months later, I had to rerun a new wire in for the turn on. Funny thing is that it was for my friend, so I just did it to save time and money (yes, that whole 2 dollars for 20 ft of wire). I guess thats why you never should just assume what somethings for, heh.
How do you figure on needing that thick of wire for the signal? I think except for the time mentioned above, I have used 18 with no problems.
Matt
mbuchman is offline   Reply With Quote
Old 07-05-2005, 09:12 PM   #7
Mr. Wiggles
shakes's Avatar
18 works too ... I was just saying you don't want to go much smaller than that and better too big (within reason) than too small.
My JeepPC Install
Old 07-05-2005, 10:06 PM   #8
Especially if you are running more than one amp. The more you split off the voltage the more current you're going to run through the wire.
PROGRESS:
Old 07-05-2005, 10:37 PM   #9
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
hmm.....i'm using the tiny wire no problem......its fused to .5 amps so i'm not too worried
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 07-05-2005, 11:01 PM   #10
SickVette's Avatar
SickVette is on a distinguished road
If that wire can not handle enough current to turn on a amp how is it going to handle the current it takes to turn on a radio? As in the wire is used to ground the head unit to the same location as the amps.
It can be used for ground or turn on. Personally I clip them off and just run the wire.
SickVette is offline   Reply With Quote
can noise be the cause of cheap RCA cables? chicochu Newbie 25 06-24-2005 07:40 PM
coaxal cable to rca cables? Cartunes General Hardware Discussion 5 04-25-2005 08:38 AM
FS: Lilliput RCA cables, memory PaCMaYNE Classified Archive 0 10-24-2004 07:27 PM
Making LONG RCA cables for interior walls? bosstone74 General Hardware Discussion 8 09-05-2004 02:06 AM
RCA Cables How To owenjh General Hardware Discussion 22 02-01-2004 08:06 AM
