07-25-2005, 07:10 PM
#16
ive been reading. DAC is digital to Analog converter, sweet. it seems this is the way to go. Would i need "two" converters since I have 2 amps, one for my sub amp and another for my component amp? also Should I buy a motherboard with SPDIF Outs? or does the Audigy2 have SPDIF Outs..very interested in this digital audio, let me know thanks.
07-25-2005, 10:11 PM
#17
_
hrmmm....maybe a trip to the "can a CarPC compete with a HU" thread is in order??
http://www.mp3car.com/vbulletin/car-audio-faq/40351-can-carputer-compete-head-unit-sound-quality.html
go spend some time in that thread....you'll get a lot of answers to your questions as well as a better understanding of what you are getting into..
when you say your system sounds great and that it hits really hard in the same sentence, i'm gathering that you aren't exactly worried about sound quality, but more worried about it just being plain loud....there IS a difference....a BIG difference
07-25-2005, 10:20 PM
#18
well the cdt eurosports are a awesome set of components..they are $800 but i got em for $300 ( dont ask  ) ..anyways i have loud, clean bass with my w6's that have a perfect tone and they dont overpower the components if I dont want them to..its one of the best sounding systems ive heard  hehe..but i'll read that thread and see whats up..but i havent found any info on spdif and DAC's on this board.
07-25-2005, 10:57 PM
#19
Super Moderator & Wal-Mart Greeter
If you got the bucks man, go digital. Best quality you can get I'd think.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
07-25-2005, 11:19 PM
#20
_
optic is going to be your best bet....SPDIF isn't a true optic source, but it's a best alternative IMO
of course it's one of hte best sounding systems you've heard...it's the one in your car..it's also tuned to your tastes and your music and it's the one you probably have the most experience with...lol
07-26-2005, 12:14 AM
#21
red gta vr6 lol yup, you are correct  ..I guess i need two DAC converters..how much do those run??
07-26-2005, 03:30 AM
#22
You do not need two dacs. As most have 5 channel line outs plus sub.
The one we use is made by Audiobahn
ADD51T
1/2 Din 5.1 Dolby® digital, DTS® surround sound decoder with remote
DSP — PCM, Dolby® Digital (AC-3, DTS®), Pro Logic® II, Pro Logic®, Movie, Music
Two Digital Inputs — Optical and Coaxial
Three Analog Inputs — RCA
Six 9v Audio Outputs (LF, RF, C, LR, RR, SUB)
Two composite video signal inputs
One 2.2 volt composite video signal output
Delay functions
Sound field effects
Dimensions: 7/8" (H) x 7" (W) x 5 1/8" (L)
So you see you just route the line outs from the dac to your amps just like from your HU. Car PC to Dac via coax or optical. Line outs from the dac to amps.
07-26-2005, 04:08 AM
#23
On the other hand though you have to undrstand that PC's and their sound cards and drivers are not designed with audiophile functions in mind. They are designed mainly for the gamer and playing DVD's
Take for instance the pioneer 9600 HU it has built in crossovers for it's mids and highs channels as well as it's sub woofer outputs. It has equalization for it's independent channels and a host of other features. It uses a 24 bit burr-brown decoder.
It is in this area that PC fall way short. You have EQ built into the sound card driver and thats about it. You have to do 90% of your eq and sound processing outside of the PC. Things as simple as front rear fading or independent stereo balance adjustments can be a pain or just unavailable in the software drivers.
Most high HU's have saveable user presets for all of these settings. PC's so far are sketchy in this regars allowing to save some profiles but not others.
All in all it takes much more time fiddling and adjusting a Car PC system to sound as good as a head unit because they were not intended for that purpose. What is a fifteen minute operation on a high end head unit can be a 3 hour ordeal on a car PC. So you have to decide whether it is worth your time and effort. Once set up though a quality Car PC system will sound as good as a quality HU.
07-26-2005, 08:12 AM
#24
_
to go out from your pc direct into yoru amps without boosting the signal voltage is asking for noise and low quality sound...
I'd recomend using an EQ or the like (I use the alpine processor for this) to boost your line level voltage to get a much more clean signal among other benefits
by using the alpine unit we were able to still function like a head unit but I was able to not have a head unit in my car...the alpine unit just takes care of all of the processing, etc
08-30-2005, 11:59 PM
#25
Quote: Originally Posted by b8bboi
Yes. But that's like you convert your grandpa's collection of VHS into DVD's. They're DVD's now but they'll still have ****ty VHS-like quality.
Thats actually not completely true. When you have an MP3 encoded at a lesser bit rate, all it means is it is compressed, via an encoding algorithm (typically lame). Since the way it is compressed is via a constant operation or algorithm, it is possible to decompress the MP3 some in order to gain some quality back, however typically you have to increase the bitrate 2x, so if you upconvert to 256 from 128 you should notice drastic improvements in your quality.
Now I understand some of you out there may say, well hey if you can decompress it to gain audio qualitywhy not just make a player capable of doing that and retain the same amount of disk space? Well the answer is computers are not yet fast enough to transcode an MP3 in real time, it must be done in an operation and be physically recoded, software isnt capable of it.
08-31-2005, 12:51 AM
#26
if computers are not yet fast enough to transcode an mp3 in real time then how can we listen to them?
additionally even if that was true you would have to have some super fantastic decoding program, one that decoded slower than realtime, and then you would have to recompress it again, which for lossless formats is never a good idea.
i have no idea about what you are on about being physically recorded, because analog recording is only going to furthur reduce quality
Signature: [==||========] 20% complete
08-31-2005, 07:42 AM
#27
i suggest reading up on the sound quality coming out of the new "pro" XFI cards by creative,
apparently playback of CD,s is especially good
Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
08-31-2005, 12:50 PM
#28
I'm afraid I have to disagree with this. While this works for many things, such as opening up an archive such as a zip, rar, lzh, this works because these compression methods are lossless.
While the nature of mp3 allows different vendors to compress using slightly different schemes, mp3 is not a lossless format. Most often, encoders use the way we hear to remove some of the content in order to achieve compression, then combine this with a lossless compression algorithm. Regardless, this removal of content is inherantly lossy. Often, if compression is set high (to say 128), some of the lower and higher end notes are removed. These cannot be brought back by re-encoding.
No matter what, when you attempt to re-encode, you're doing to have to decode the current signal. If it's poor quality (at 128k), then you're going to decode the poor quality signal (the same as if you were playing it), and then re-encode that.
08-31-2005, 06:55 PM
#29
Hey Red...you always have good advice, I was wondering what Alpine processor you used in your setup...is it just called an Alpine "processor" or is it a crossover? Also, does the processor automatically boost your line level voltage, or do you have to adjust certain settings?
08-31-2005, 07:30 PM
#30
_
http://iweb.alpine-usa.com/pls/admn/...ory=&p_main=10
that's what I'm using.
it's more than just an EQ, it's a full processor, surround sound decoder (though I'm not using that part of it), etc.
it boots line voltage to 4v max....no adjustments needed
| Thread Tools |
| Display Modes |
Linear Mode
