Old 09-01-2005, 04:34 AM   #31
00christian00's Avatar
00christian00 is on a distinguished road
Hey Red,i just changed my sound card with a professional sound card as i couldn't find an alpine h700 for less than 500 euro in italy(i paid my card 350 euro) and at least i don't have to recable for just a controller,and i can use the awesome dac of the card.
The card is that :
http://www.esi-pro.com/viewProduct.php?pid=2&page=1
Specifications
<WaMi Rack 192X>
1. Analog Input Specification
1) Type : 4 channel analog line input - 1/4" TRS Phone jack (X4)
- Balanced XLR Connector (X4)
2) Level : +4dBu balanced, +4dBu Nominal, +22.5dBu Max (Gain +0dB)
3) Gain Adjustment : +0dB ~ +20dB
4) Impedance : 10K ohm
2. Analog Output Specification
1) Type : 8 Channel analog line output - 1/4" TRS Phone jack (X8)
- Balanced XLR Connector (X2)
3) Attenuation : Digital -127dB ~ 0dB, 0.5dB Step Size (with Mute)
4) Impedance : 100 ohm
3. Mic preamplifier Specification
1) Sensitive : 66.5mV max (Gain +0dB)
2) Gain Adjustment : +20dB ~ +40dB
3) Impedance : 1.5K ohm
4) +48V Pantom power
4. Headphone Amplifier Specification
1) Output Power : 60mW Max
2) Dynamic Range : 110dB (Typical)
3) S/(N+D) Ratio : 101dB, 0.03% (Typical)
5. Sample rate : 16, 22, 24, 32, 44.1, 48, 88.2, 96, 176.4, 192 KHz
6. A/D Convertor Specification
1) Type : 24bit, 192KHz, 128X Oversampling (Full Differential Input)
2) Dynamic Range : 123dB (@ -60dBFS with A-Weighted)
3) S/(N+D) Ratio : 105dB (@ -1dBFS, measurement method)
4) Frequency Response : 6.5 ~ 21.768KHz, +/- 0.001dB (@ fs=48KHz)
6.5 ~ 43.536KHz, +/- 0.003dB (@ fs=96KHz)
6.5 ~ 87.072KHz, +/- 0.007dB (@ fs=192KHz)
5) Interchannel Isolation : 120dB
6) Interchannel Gain Mismatch : 0.1dB
7. D/A Convertor Specification
1) Type : 24bit, 192KHz, 128X Oversampling, 8times Digital filter
2) Dynamic Range : 106dB (@ -60dBFS with A-Weighted)
3) S/(N+D) Ratio : 90dB (@ -1dBFS, measurement method)
4) Frequency Respons : 0 ~ 21.768KHz, +/- 0.05dB (@ fs=48KHz)
0 ~ 43.536KHz, +/- 0.05dB (@ fs=96KHz)
0 ~ 87.072KHz, +/- 0.05dB (@ fs=192KHz)
5) Interchannel Isolation : 100dB
6) Interchannel Gain Mismatch : 0.2dB
8. Digital I/O Specification
1) Type : Coaxial I/O Connector
2) Format : IEC-958 Consumer(S/PDIF),IEC-958 Professional(AES/EBU)
3) Sample Rate : 32,44.1,48,88.2,96,176.4,192 KHz
4) Resolution : 24 Bits
I calculated with a program and and it came out that the output voltage are 1,2 v nominal(4dbu) and 10v max(22,5 dbu) so the voltage should be enought.
Have i understood well?Or will the card have pre-out always lower than a h700?
00christian00 is offline   Reply With Quote
Old 09-01-2005, 09:15 AM   #32
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
That looks nice, but I have a few questions....
for most people the problem with the Alpine unit is finding a place to put the controller, seems like this would be just as much of a problem, no?
how do you power it? through an inverter? if so that's taking one step forward and two steps back for sound quality.
the connections? I don't see anything on there that would fit in the car audio world....am I missing something?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-01-2005, 10:28 AM   #33
Why i have to look for a place for this?This goes back with the amplifiers,i don't have to touch it.Its only purpose is to connect the pc with the amps.
It has a pci card that power all the rack,so one step forward and no step back
For the connection it has 8 mono 1/4'' jack for output and two balanced XLR(which i have on my butler tube amplifier) with 48v phantom power.
You can see here the outputs and the pc connection :
Tonight i'm gonna test it,i hope i can get good result.
My biggest fear is that it use much more power than the previous card,and i think my poor opus is already at the max.
Old 09-01-2005, 10:48 AM   #34
_
ahh - ok, well you have fun with it!
Jan Bennett
Old 09-01-2005, 05:14 PM   #35
Ok,here are the result.
With the XLR the output is very noisy,i think it doesn't have enough power to do the 48v phantom,and i don't have enough power even for just the usb touch screen.
Using the jack the touch screen was working fine,but the only cable i had was a very thin and poor one,and i still had a little noise,i hope it's just a cable issue.
The great thing is that now,with the gain of the amplifier at the minimum, i have almost the same power as before with the gain at the maximum.That with the tube amplifier,with the other cheap one i haven't noticed a great difference,someone know why?.
Overall the sound seem much cleaner but maybe it's just an impression,it seem now more cold and flat,without personality
I think it's time to take the car to a professional installer,the previous installer was a total incompetent.
can a carputer compete with a head unit for sound quality? emdzey01 Car Audio FAQ 489 04-03-2007 03:16 AM
XM Radio Sound Quality - What Happened? tbird2340 FrodoPlayer 20 07-14-2005 06:59 PM
Hard audio quality problem: Noise / Ground loop? Burat General Hardware Discussion 14 09-09-2004 07:08 AM
Wanted: Clean sound from carpc slushieken Car Audio 8 06-20-2004 10:17 AM
Improving sound quality... Seabass General Hardware Discussion 4 03-27-2004 01:38 AM
