Old 08-01-2005, 12:24 PM   #16
SickVette's Avatar
SickVette is on a distinguished road
Microtime....Peripheral Electronics makes a part called a SPK. That is a speaker switcher. It is two channel and designed to route a signal from to sources to a single set of speakers. That should work for your speaker switcher.
They also make two other parts that allow you to have an aux input to your factory radio. These two parts are supposed to work on 98 Toyota factory radios.
Those parts should be able to help you at least get started. What would be best if their was a way to output 12v from your computer before the GPS talks. If you could do that then it is easy to make a relay switcher that would allow the GPS to override anything that is playing through the speakers.
SickVette is offline   Reply With Quote
Old 08-01-2005, 12:43 PM   #17
Zebelkhan's Avatar
Zebelkhan is on a distinguished road
Quote: Originally Posted by greenman100
then how do mixerboards work? they take signals from 2 sources (guitar, CD player, microphone) mix them, and give a single output
Like I said I don't know much about electronics so I could be wrong, or, mixerboards have something specific that deals with it. I am sure they are more than just a knob. All I know is that I have mixed two outputs (an old stereo and a tape player/recorder) together to a single set of speakers and after a while my stereo sound got really sick!
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 08-01-2005, 10:19 PM   #18
microtime is on a distinguished road
I think I found it....
I saw this on another posting. I believe this will do it without me having to make a circuit on my own.
ftp://208.187.38.55/Phoenix_Gold/Man...D44_Manual.pdf
I can't believe this is that hard to do. I'm amazed I'm the only person who wants a head unit and a PC to make noise automatically without a switch or the like....
Next time I wouldn;t have gotten a Mocha but did a smal form factor Mobo somewhere else. This way I could have had a realsound card and not have to rip apart a USB Oronico WIFI card. My kingdom for a a few PCI slots...
microtime is offline   Reply With Quote
Old 08-01-2005, 11:54 PM   #19
WiCKeD 5.9L is on a distinguished road
Not to disappoint you, but I posted this last night and deleted it, because I didn't want you to FUBAR your speaker system. My Kicker amp also has low level & high level inputs, however it specifically says NOT to use them at the same time. Not sure what it will do, but smoke and sirens spring to mind.
Here is the illustration from the manual:
WiCKeD 5.9L is offline   Reply With Quote
Old 08-02-2005, 01:53 AM   #20
Fusion Brain Creator
greenman100 is on a distinguished road
ok guys think about this
when you take a stereo (2 channel) amp and bridge the outputs, you are connecting 2 separate amps together.
what's the difference here?
greenman100 is offline   Reply With Quote
Old 08-02-2005, 03:22 PM   #21
integramodder is on a distinguished road
I would think so long as you are matching low level to low level and high level to high level that you shouldnt have a problem....
integramodder is offline   Reply With Quote
Old 08-02-2005, 03:38 PM   #22
agreed
Old 08-02-2005, 10:39 PM   #23
walky_talky20 is on a distinguished road
The 98 Avalon with the 7 speaker system has a factory amplifier. To have both the audio from the Factory Head Unit as well as a PC (GPS) you need to build a line level mixer. Something with two stereo inputs and a single pot for crossfade would be ideal. Here is a link to a simple mixer circuit. I'm sure there are others that are simpler and more suitable for this purpose. (Like I said if you could build one with a single pot that would be best.)
http://www.epanorama.net/circuits/linemixer.html
The only small problem you might have is that the factory amplifier has 4 inputs instead of 2. FL FR RL RR. A solution would be to only put the PC (GPS) into the front inputs. FL FR.
Hope this helps.
walky_talky20 is offline   Reply With Quote
Old 08-03-2005, 02:35 PM   #24
I believe the solution from walky_talky20 will do it. I just need to build the circuit now. I made the Radio Shack trip and have all the pieces except the pots - they don;t cary them, off to componenets catalog people now. I still have 1 questions though...
This part:
I do want to use all 4 speakers though,,,, When I listen to MP#'s or have a DVD movie I'd want it everywhere? Can I build 2 mixers and tie them into the front and rear channels and put diodes in the positive lines so that they don't feed back? I'm almost there.....
also, does anyone have the wiring diagrahm's for these?
Old 08-03-2005, 11:40 PM   #25
I sent you the wiring diagram for the 98 avalon (pdf). As far as mixing the pc into all 7 speakers. You have options. There might be a simpler way using less expensive pots, but I would use two 4gang pots. One for the front and one for the back. The schematic I put up earlier requires 4 pots, but these can be replaced with one 4gang pot which is essentially a crossfade. And you double it to add the rear. Add a second 4gang pot or go to an 8gang pot, but I think the 4gang will be hard enough to find (alternatively you could go to 4 double gang pots, but thats not very user friendly). This is creating 2 mixers. A front and a rear. The reason for 2 mixers is to preserve the fading function: that is the ability to fade the music to the rear. With 2 mixers it is possible to have GPS in the front and RADIO in the rear. If this is not important than you can just split the output of the first mixer and send it to the amps front and rear inputs. I can draw you a schematic if you like and show you exactly where to hook things into your car wiring.
-Also I believe the 10k resistors used in the schematic could safely be changed for 5k's so as to retain more available volume from the system.
-You shouldn't need any diodes at all.
I hope I am not too hard to follow. It is a lot of stuff to think about.
Old 08-04-2005, 12:49 PM   #26
ALonDonThinG's Avatar
ALonDonThinG is on a distinguished road
Link to a simple mixing circuit to put inline before your amp
http://www.tkk.fi/Misc/Electronics/c...s/linesum.html
you can conbine two diff line level inputs .
hope it helps
Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
ALonDonThinG is offline   Reply With Quote
Wiring, fuse, amp, relay questions Vee24 General Hardware Discussion 7 05-25-2005 08:03 PM
Help hooking up subs and amp? Need advice... jedi7001 Car Audio 6 05-17-2005 02:28 AM
amp +smoke = bad USUALLY pcman_cortina Off Topic 10 07-09-2002 04:20 AM
Me=Newbie: Do I need an amp? Strix General Hardware Discussion 6 06-28-2002 09:11 AM
Audio and amps - building a preamp. claylong Power Supplies 18 03-26-2002 10:45 AM
