Old 08-10-2005, 05:24 PM   #1
volum3rider is on a distinguished road
Popping Noise
In my carputer im running and M1-ATX power supply. It has a built in amp remote switch that turns on the amp after the computer starts. It works fine but I still get a popping noise from my speakers when windows boots up. The amp turns on right before windows is done loading. The problem with this is that I had another amp hooked up and it worked fine before. I didnt move any wires or anything like that, I just took out the old amp and put the new one in without moving any wires around. Everythings grounded correctly so I know its not that. Any suggestions?
volum3rider is offline   Reply With Quote
Old 08-10-2005, 07:27 PM   #2
schreibers is on a distinguished road
I had a similar situation with turn off pop with my first real car audio setup. Everything worked fine but when I threw my Orion Concept 97.2 EQ in the mix I rad into trouble. What I ended up doing is put a small 400uF capictor and a diode in line with the remote wire before it went to the amps/eq which elimited the problem.
You're having the opposite problem however after some googleing it seems the same thing could be used to prevent turn-on pops and delay the turn on of that device.
Dave Navone has one you can buy for 16.00 at http://www.autosound2000.com/ or there seemed to be a schematic at crutchfield.com where you could build one if I remember correctly.
schreibers is offline   Reply With Quote
Old 08-11-2005, 02:44 AM   #3
Cool thanks
Old 11-20-2005, 04:32 PM   #4
pasic's Avatar
pasic is on a distinguished road
volum3rider, did that work for you by the way?
pasic is offline   Reply With Quote
Noise (from engine and other sources) HELP!!! sstylos Car Audio 6 09-20-2005 01:41 PM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 11:31 AM
Finally got rid of the popping noise! XxAndyxX General Hardware Discussion 4 10-19-2004 02:24 PM
noise investigation lookinco Power Supplies 14 09-23-2004 03:41 AM
Noise!! AARGH! sq_geek General Hardware Discussion 23 09-21-2004 02:33 PM
