The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 08-15-2005, 11:44 AM   #1
My Photos: (0)
Email I recieved from Creative about SPDIF
I sent an email to Creative last night regaurding the digital SPDIF output on the regular ZS sound card and how it could be converted to an coaxial plug. Well before I even recieved the email I found exactly what I needed here http://www.ramelectronics.net/html/RCA-mini-spdif.html and bought it.
I got the email back this morning from creative and it had a lot of information in it that I was unaware of. Here is the main part of the email that had me confused I should say.
"CONNECT THE DIGITAL OUT TO A RECEIVER
1. Use a stereo minijack (1/8 inch) to RCA cable.
2. Connect the minijack end into the digital out on the sound card
(This is the furthest port away from the firewire SB1394 connector).
3. Connect the left (white) RCA connector to the SPDIF coaxial input on
your receiver.
4. Leave the right (red) RCA connector disconnected.
SET THE AUDIGY2 TO USE DIGITAL OUTPUT
1. Go to Start > Programs > Creative > SB Audigy 2 > Surround Mixer
2. Click on the (+) above the main volume control.
3. Make sure there is a check next to "Use Digital Output Only"
4. Please also verify this under start > run > SNDVOL32 > advanced
DISABLE AC3 DECODING
1. Go to Start > Programs > Sound Blaster Audigy 2 > Audigy HQ > Device
Controls > Decoder
2. Select "SPDIF Passthru (Dolby Digital / DTS Digital Out)"
The soundcard will now pass the AC3 signal and raw PCM data to your
receiver to be decoded as 5.1 channel audio.
Please note that only AC3 audio (such as audio from DVD movies) will be
in surround sound. All other audio will be processed by the receiver as
PCM, and thus you will only hear the two front channels. This is due to
the limitation of the S/PDIF connection allowing only 2 channels to
cross over a single wire. More information about this can be found at http://www.dolby.com.
Note: There are audio options within the DVD software that need to be
configured for Dolby Digital pass-through. These options are different
depending on what software you have. If you need clarification on what
needs to be enabled or checked, then reply with all the options
available under Audio properties within your DVD software.
Let me know your thoughts and if there is anyway around this.
M5AM is offline   Reply With Quote
Sponsored Links
Old 08-15-2005, 12:05 PM   #2
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
bump! cause I'd like to know!
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is online now   Reply With Quote
Old 08-15-2005, 01:23 PM   #3
Vehicle: '91/Honda/Civic
My Photos: (0)
your receiver.
Controls > Decoder
What part is confusing you? What's confusing me is:
your receiver.
I thought that digital coax cables only had one pair. This implies that you can use regular RCA cables.
DRWeside is offline   Reply With Quote
Old 08-15-2005, 01:32 PM   #4
_
My Photos: (90)
that's one thing that caught my eye too, but I thought I just wasn't reading it right or just didn't get it.....
digital coax is just a single RCA end isn't it?
Jan Bennett
Old 08-15-2005, 01:43 PM   #5
My Photos: (0)
Yeah it is but from what I heave read it a digital coax and standard coax are the same thing. The only difference is the impedance level on the cable its self. The digital coax has a 75ohm impedance and the standard coax is 50ohm.
Here is a site I found discussing that. http://forum.ecoustics.com/bbs/messages/5/1370.html
What I am confused about is the fact that by playing regular MP3s through the computer into my headunit I will only recieve 2 channel sound, and doesnt that mean that only my front channel will work and I will not have a sub or anything like that? Or did I missunderstand that. Because I am under the impression that my 1 channel is front driver and 2 channel is front passenger.
Old 08-15-2005, 01:56 PM   #6
My Photos: (0)
That's what I thought. I'll have to mess around with that some more. I had purchased a digital coax cable, but after trying tons of different settings, I couldn't get my receiver to play any music from the digital input. Hopefully, I still have that cable around.
Old 08-15-2005, 02:02 PM   #7
My Photos: (0)
I think you misunderstood.
Your headunit should have a digital input. If this is not the case, then you won't be able to use the SPDIF-out on that soundcard.
Old 08-15-2005, 02:14 PM   #8
Maukio's Avatar
Vehicle: '99 Honda Accord
My Photos: (0)
your receiver.
Well, I think what you are confused about is ideally you want to use this cable just like M5AM said. Creative tells him in the e-mail reply to use a stereo cable. It would be just like this but with two contacts on the mini side and two RCA connectors on the other side. One of those two sides (the red they say) is basically useless when you use a stereo cable.
'99 Accord LX
Pics of CarPC Setup
Maukio is offline   Reply With Quote
Old 08-15-2005, 02:46 PM   #9
My Photos: (0)
LOL
The answer to my question is that the difference is in the impedance between analog and digital cables.
The answer to his question is not so clear, because he hasn't said what make and model HU he has in his car.
Old 08-15-2005, 02:49 PM   #10
_
My Photos: (90)
he being the original person starting this thread?
it's an eclipse unit...for the life of me I can't remember the model though.....
Jan Bennett
Sponsored Links
Old 08-15-2005, 03:04 PM   #11
My Photos: (0)
OK
I think that the two front channels in this case are referring to the front channels in a HOME theater setup. Am I wrong or wrong?
Edit: A good HU should pass on low frequency sounds to a subwoofer no matter the type of audio being played.The problem you may have is that your rear speakers may not reproduce of the 2 channel music being output by the HU, if they are being used as the surrounds. Again, a good HU should differentiate between the types of audio and reproduce the sound accordingly.
Old 08-15-2005, 10:02 PM   #12
My Photos: (0)
Thanks for the help. It is an eclipse 8454. I will only be running my front components and 1 subwoofer. This a follow email I just recieved.
"I gather you are hoping to have surround output as well from normal
music files playback. Usually for dvd movies, they will have discrete
channels if they support dolby digital.
For digital connection, the CMSS feature on our sound card will not have
any effect for it as it is for upmix during the use of analog
connection.
Unless your speaker system has a speaker system with a decoder for upmix
purposes. You may then set it to upmix from stereo to surround.
Else I'm afraid you will have to stick to analog connection in order to
have surround effect.
To setup the CMSS feature on the software I have included the steps for
you to try out.
TO TURN ON CMSS IN Mediasource
1. Open MediaSource (Start, All Programs, Creative, Creative
MediaSource,
Creative MediaSource Organizer).
2. There should be an EAX button underneath the Record button at the
bottom of the screen, towards the left. Beside this button, there
should be a
small ellipsis button (. . .) that you can press. Click on this.
3. Go to the CMSS 3D tab and check the box next to "Enable CMSS 3D""
Old 08-15-2005, 10:18 PM   #13
_
My Photos: (90)
I'm a little confused then....why are you concerned with surround sound?
Jan Bennett
Old 08-15-2005, 10:56 PM   #14
My Photos: (0)
I am not concerned with surround. I am not sure why they assume that. I just want stereo sound and want my sub to work with it.
Old 08-16-2005, 08:11 AM   #15
_
My Photos: (90)
I don't see why it shouldn't then....
Jan Bennett
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Renault Scenic II - SPDIF PC Vicne Show off your project 22 08-27-2005 03:16 PM
Enable SPDIF on EPIA M10000 titaniumkingpin General Hardware Discussion 15 02-28-2005 04:07 PM
Is all coax/optical spdif output created equal? Choser General Hardware Discussion 26 12-19-2004 02:48 PM
5.1" to stereo + SPDIF lookinco Car Audio 5 08-08-2004 12:52 PM
ps2 pelican remote w/ creative reciever & girder ShinkunoNamida Input Devices 0 04-26-2003 02:00 PM
Sponsored Links
Ad Management by RedTyger
