Old 08-23-2005, 08:09 PM   #1
michaelrj9's Avatar
michaelrj9 is on a distinguished road
minimum distance between power & rca wires
hi all thanks for looking...
I have the power & rca cables seperated running down the length of the car..
my question is what is the minimum distance to insure no interference from them? 1ft,2ft etc...
why am I asking? read below..
I am trying to move my amps to the drivers side of the car in the trunk running parallel with the length of the car.The rca cables are running down the drivers side.The power cable is on the passenger side of the car.
The rca input on the amps is twords the rear of the car.
I am having trouble keeping the wires seperated (in the trunk area)unless I swap sides the power and rca cables are running down the car which then I will need new power cable because it will be too short then a very long rca cable to go down the side of the car to the end of the trunk then move it over to the driver side where the amp is.(big pain to do)
Is there anything else I can do?
right now it seems the farthest I can get them apart is about 1 foot or a little less and that is only in 1 spot then they get farther apart ..
would putting a 1" thick board between help?
any ideas out there?
or using stinger expert or dream rca cables or something similar help?
right now I am using stinger HELIX SERIES cables..
Thanks Michael
michaelrj9 is offline   Reply With Quote
Old 08-24-2005, 05:29 AM   #2
fonseca's Avatar
fonseca is on a distinguished road
It's generally not a problem to cross them if that would help, try to cross at a right angle. It's when you run them alongside each other that you run into trouble.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
fonseca is offline   Reply With Quote
Old 08-24-2005, 09:40 AM   #3
sharpy39 is on a distinguished road
i agree with the above post.
yu could also, if it would help, run yure rca cables down the middle of yure car.
sharpy39 is offline   Reply With Quote
Old 08-24-2005, 10:02 AM   #4
sdashiki's Avatar
sdashiki is on a distinguished road
Its been my experience that unless you are getting noise in your music etc, dont worry about it. Once you have some noise to deal with, you can move wires while the noise is present and see where to move them.
Also, power usually runs on the drivers side, cuz its the easiest place thru the firewall. Your setup is different.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 08-24-2005, 11:01 PM   #5
Spyder1331's Avatar
Spyder1331 is on a distinguished road
My professional opinion...
As a MECP certified tech, the best way to run signal and power is seprately. Power on one side, signal on the other. As for which side the power should be installed it is totally dependant on the car manufacturer. If you do need to cross/intersect the wires it should be done at a 90 degree angle.
Spyder1331 is offline   Reply With Quote
Old 08-25-2005, 01:19 PM   #6
w143r is on a distinguished road
If you only detect minimal noise, try better cables. They have shielding that would help in this situation.
w143r is offline   Reply With Quote
Old 08-26-2005, 02:22 AM   #7
WhiteRabbit is on a distinguished road
Id worry more about ground loops than induced noise.
bottleneck theory. take care of the biggest noise factors first. they can be miles apart, if you have ground loops, you are in trouble.
chances are, youll never have a problem with induced noise. fully seperated or not.
WhiteRabbit is offline   Reply With Quote
Old 08-27-2005, 12:24 AM   #8
Spyder1331's Avatar
Yeah ground loops SUUUUUUCK, and chasing them sucks even more.
Old 08-28-2005, 08:18 PM   #9
NiN^_^NiN's Avatar
NiN^_^NiN is on a distinguished road
I have my power wire and RCA wires cable tied to each other without problems.
I did get quality power cable and oxy free RCA (cost around $70 but i might aswell go for the best for the audio) i also have the VGA cable next to the power aswell and i have no problem at all
Also got usb cable tied to the rest of the cables so i've got no problems with quality cables.
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 08-28-2005, 08:28 PM   #10
Jcarere is on a distinguished road
12 inches is the minimum but not many people experience problems. Like others have said Its best to usegood quality cables and check for ground loops.
Jcarere is offline   Reply With Quote
Old 08-30-2005, 06:33 AM   #11
miztahsparklez is on a distinguished road
heh i got lucky in my car i guess. im running balanced input controllers for my amps so they go straight from my soundcard into the controllers. controllers bump up voltage to 9v+ though my wires for audio and power were run as far apart as possible, some points had to be run near eachother, and i have no noises.
however, when i had a regular indash dvd, man i dont know what it was, but the only way to get rid of MOST of the noise was to run it through an audiocontrol linedriver/crossover. and even then i think there was some noise issues still.
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline   Reply With Quote
Old 08-30-2005, 02:02 PM   #12
you're lovin those BLD's, arent you =p
thats the beauty (theoretically) about the balenced inputs. you could wrap the power wire around your signal wire and no issues with induced noise...
hey when are we doing another cluck U run? next month?
Darn ITPS! Need power help! DJ-FrosT Power Supplies 1 07-16-2005 08:40 PM
correct way to run power & speaker wires? michaelrj9 Car Audio 15 07-16-2005 05:59 AM
Power Laptop without tearing wires! damo642 General Hardware Discussion 1 03-06-2005 01:47 PM
LCD screen power suplies and rca hook ups turbopseidon Newbie 0 05-23-2004 04:05 PM
Power wires Dima General Hardware Discussion 2 08-16-2000 10:42 AM
