Old 08-24-2005, 11:45 PM   #1
acidshock is on a distinguished road
Muffled/"Bassy" audio
Hey guys. I got my carputer installed and working for the most part but I am running into a problem. The audio sounds a bit muffled or like there is way too much bass. I have a couple suspects to this but wanted to get some outside opinions before I tear apart my current setup.
I am using the AC97 card and my car has the stock amplified system that is in a Mustang GT 2001. Its the 480W amplified system(think bose.) I have found a converter or what not that allows me to encode the audio into the amplifier(since if you dont the amp plays really funky sounds)
To describe the way the audio sounds it sounds like your at a performance and then walk outside for some air and are able to hear through the wall. I should also mention that the audio can really crank up loud so I dont think its necessarily a lack of power. My best guess is that it is the stock amplifiers and that they probably need to be replaced. Any ideas?
acidshock is offline   Reply With Quote
Old 08-25-2005, 05:43 AM   #2
Lee232's Avatar
Lee232 is on a distinguished road
Err do you have a bass boost button turned on on the amp, or the amp set to x over?
Lee232 is offline   Reply With Quote
Old 08-25-2005, 01:17 PM   #3
w143r is on a distinguished road
Check your EQ on your PC. You might have doubled the bass boost so it boosted the bass from the PC and then from the HU so it sounds like ****. Use only one EQ and you should be fine
w143r is offline   Reply With Quote
Old 08-25-2005, 02:51 PM   #4
Ive actually cut the head unit out of the loop. Just computer, straight to the stock amps. I think I will play with it for a bit and see what I can do. If it doesnt correct it I guess here comes some new speakers and an amp.
Old 08-25-2005, 03:08 PM   #5
Check your cables also, there might be a distortion due to bad connectivity. Try playing music using default EQ settings and then work from there.
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 05:31 PM
designing audio system 1DeepG Newbie 3 06-29-2005 09:48 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 06:37 PM
XMDirect Digital Audio Project ? Retsaoc General Hardware Discussion 1 10-11-2004 10:26 PM
