Old 08-27-2005, 07:48 PM   #1
casurfer911 is on a distinguished road
bmw planning questions
im planning a computer for my 1990 535i and i dont know what to do about the audio. It has a stock 8-speaker amplified setup. I think the stock head unit only pushes 5 watts. Is there a way i can wire it straight from the computer to the amp. The amp does not have rca inputs it has positive negative front/rear, right/left. Anybody have any ideas?
casurfer911 is offline   Reply With Quote
Old 08-27-2005, 08:03 PM   #2
roadhog's Avatar
roadhog is on a distinguished road
I have a Ford Probe with a similar setup.
If you can identify the wires, and get a matching connector then just wire the computer straight to the amp. If you can't lay your hands on a connector you could always cut the wires, but then there's no going back
It shouldn't matter that the inputs have common ground, just split the PC ground to each negative input.
I used the motherboard's onboard 4 channel sound, then found that most PC apps use only the front two channels for music... but it's good for films etc
roadhog is offline   Reply With Quote
Old 08-28-2005, 02:00 AM   #3
that sounds like what i want to do. Do you think there will be an easy way to get it to put the same sound out to the back other than wiring them to the same source? Because i still want it to play music on the back speakers. I think a lot of this is going to be trial and error
Old 08-28-2005, 02:11 AM   #4
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
You could always soder the connector back
0l33l is offline   Reply With Quote
E46 BMW guys, any thoughts? GeddyT Newbie 25 03-09-2007 10:08 AM
noob questions for custom carputer for BMW jokgga Newbie 5 03-09-2006 04:42 AM
Some questions about the systerm I'm planning on buying. doublet Newbie 1 08-20-2005 12:21 AM
Will someone be willing to answer a few questions about the Vietnam War for an essay? guitar333 Off Topic 6 05-25-2005 12:53 PM
BMW 330ci Planning Cecplex Newbie 12 08-25-2004 01:21 AM
