Old 08-27-2005, 11:55 PM   #1
jnye6625 is on a distinguished road
CarPC with stock radio integration
I have a Nissan sentra with the rockford audio fanatic package, and i would like to be able to plug my mp3 player of car pc directly into the stock HU. Does anyone know if the stock HU is capable of a aux input. I know the back of the CD player has a circular connector with multiple pins. I'm thinking this might be where to hook it up. I'll probe the pins tomorrow and find out if there is any current to any of them, but it would be nice if someone else knew anything abou it before i go poking around in there. Thanks
jnye6625 is offline   Reply With Quote
Old 08-28-2005, 06:48 AM   #2
numbers's Avatar
numbers is on a distinguished road
What year?
numbers is offline   Reply With Quote
Old 08-28-2005, 10:53 AM   #3
mwcmic's Avatar
mwcmic is on a distinguished road
you can try using FM modulator instead, its easier
mwcmic is offline   Reply With Quote
Old 08-28-2005, 11:17 AM   #4
megadivers is on a distinguished road
Get an I-Pac. It works perfect!
megadivers is offline   Reply With Quote
Old 08-29-2005, 12:37 AM   #5
its a 2002 sentra ser spec v with rockford system
I just found out that it is possible to connect a cd changer to this system. Does anyone have any information on how to make my own (or where i can get) an adapter? Thanks
Old 08-29-2005, 01:03 AM   #6
Stacker is on a distinguished road
The answer was above... Get an FM modulator. Hassle free answer.
Stacker is offline   Reply With Quote
Old 08-29-2005, 02:24 AM   #7
numbers's Avatar
I'm going out on a limb here, but I'd suggest that if he paid the extra for an upgraded sound system, fm modulator quality is not exactly desirable.
I should be able to get the factory wiring diagrams for you. I'll let you know.
Old 08-29-2005, 11:24 AM   #8
Yes, i would definately hate to get a modulator. The sound quality is excellent (at least i think so) for stock, and thats also why I dont want to get a different head unit. Numbers - if you know a way to use my cd changer input as an auxilary that would be great. I know if you add the option for a cd changer, it mounts in a different location on the dash, and must plug into the connector on the back of my head unit. Thanks for your help!
Old 08-30-2005, 12:44 AM   #9
anyone have any information yet about the input for cd changer turned into aux input
Old 09-13-2005, 11:55 PM   #10
bluekanoodle is on a distinguished road
Is it an ipod? if so check out monster's icruze line of adapters
bluekanoodle is offline   Reply With Quote
Old 09-14-2005, 06:58 AM   #11
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I hope you have your asbestos panties on, n00b....
This entire thread has been about the pros/cons of using an FM modulator with a high-end aftermarket sound system. That's what the iCruze is. Even so, the portion you quoted was referring to use of a CD-changer input, not an FM modulator.
Let's engage the brain before we click on that REPLY button. It would also help if you read the contents of the thread first.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 11-20-2005, 04:18 PM   #12
Aldaris's Avatar
Aldaris is on a distinguished road
Hey guys!
I haven't tested it, but check out this site :
http://www.installer-data.com/aacars...hcarsinst1.php
There is an adapter to convert the unused cd changer port to an aux-in!!
I've got a spec-V too and I'm seriously thinking that this option would be great!
If someone have tested it or heard about it, I would be interested to know more about that!!
See you around!
Phil
Aldaris is offline   Reply With Quote
Old 11-30-2005, 09:45 PM   #13
tyty is on a distinguished road
Peripheral is a huge car stereo OEM integration company. They only make AUX input adaptors for a nissan quest. If they don't make one for your car I assume it doesn't exist. It looks like you are stuck with an aftermarket deck or modulating.
tyty is offline   Reply With Quote
Old 12-01-2005, 12:40 AM   #14
jbors's Avatar
jbors is on a distinguished road
I'm going to have Nissan adapter in Feb 06. It will allow to control PC from Nissan headunit. It will run the same as all my Car2PC adapters...
Car pc integration with ease
Car mediacenter
jbors is offline   Reply With Quote
question about amps and a stock am/fm radio... TiTUS Car Audio 3 05-18-2005 04:58 PM
CarPC Pro v.2.2 & CarPC EZ v2.2 out of stock michaelrj9 Power Supplies 1 02-27-2005 08:50 PM
Line In Mute problem with Radio... ShawJohn MediaCar 1 08-20-2004 06:21 AM
Need some help with sending audio to stock amp orangewhip General Hardware Discussion 12 09-04-2003 02:21 PM
toyota stock radio waffffffle General Hardware Discussion 11 02-09-2001 11:03 AM
