Old 08-30-2005, 06:50 PM   #1
3onDubs's Avatar
3onDubs is on a distinguished road
Wiring 2 AMPS?
I had a simple question about wiring the carputer to my current system setup...I currently have two amps (one for subs, one for speakers). I wanted to know what is the best way to get sound from the sound card to my amps....
Should i use the regular stereo output from my soundcard?
Do i need some sort of a cable splitter to run the sound to both amps?
Will the PC give me the same power and sound quality as a 200W HU?
...THANKS...
3onDubs is offline   Reply With Quote
Old 08-30-2005, 09:12 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
as for the sound quality question - there is no way in this world that you will EVER have a head unit that puts out 200watts.....don't fall into the BS marketing hype that's plastered on the front of the radio.....if the radio is stating that, chances are it's a crappy radio
second, on the two amp question, you need something like an EQ, processor, crossover, etc. to split the sound.
that's pretty much the only way that I'm aware of to get that type of job done...not to mention it's going to usually boost your voltage level thus raising your sound floor to an at least respectable level...just for starters
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 08-30-2005, 11:36 PM   #3
kdunn926 is on a distinguished road
It really depends on the soundcard your using. For instance I am using an audigy 2 pci in my carputer (always go usb when possible it simplified mounting) and it is obviously 6.1 (left, center, right, surround r, surround left, surround back and the .1 refers to the sub). However my setup is a 4.2 setup, so I run it in 5.1, and use stereo mini to stereo rca adapters.
Typically a surround sound sound card will have 3 stereo analog outputs, each output containing 2 channels of audio, so when you split it youll get one channel with the left and right channels, one with the stereo surround channels, and one with the center and sub (LFE) channel. Now youll obviously wire the l/r and sr/sl outputs right into your component amp, then with the last center/sub output youll figure out which rca is for the sub via a speaker noise test and which is for the center channel, then you simply y-adapt the sub channel a total of 3 times. Itll look something like this:
Mono amp input L
Sub <
Sub < Mono amp input R
| Mono amp input L
L Sub <
Mono amp input R
Center -- (not used unless you do have a speaker in the center of your dash)
Now as mentioned before, each time you y-adapt any electrical signal, you are wiring it in series, which halves impedence, or doubles output, so gain accordingly on your amp. However typically this is not a problem as many people buy subs specifically for output anyway.
Now as far as sound quality and output, the wattage you will provide your speakers with depends on your speaker amp, the whole point of an amp is to turn a line level signal (computer, ipod, cd, ect) into a high-level signal that is capable of driving speakers. Sound quality from a computer is unsurpassed by any headunit i have encountered thus far, the reason for this is because if you get the right sound card you have the option of adjusting crossovers to send the right frequencies to your components and the rest to the bass, this allows for excellent sound seperation without the need for a processor or external crossover. In other words it makes sure Mariah Carey comes only from your tweeters, and that gangsta rap doesnt make it anywhere but your subs.
kdunn926 is offline   Reply With Quote
Old 08-31-2005, 05:15 AM   #4
Shotty's Avatar
Shotty is on a distinguished road
Red,
What does it mean to raise the sound floor?
I mean, i've got an audigy 2 in my carPC, without raising the voltage of my output, does upping the input sensitivity on the amp a lot result in less sound quality?
Also, 3onDubs, does one of your amps have pre-outs? Could always run a 3.5mm -> RCA into one amp and another RCA cable from that amp into the 2nd one?
Cheers, Shotty.
Shotty is offline   Reply With Quote
Old 08-31-2005, 09:04 AM   #5
_
raising the sound floor effectively means raising the voltage.
the higher thte voltage level the less likely youa re yto have induced noise....in laymens terms to say the least
in general, the higher you have the gains ont he amp the less the SQ, but there are so many variables that go into that that I almost hesitate to make such a blanket statement like that
you use the gains to match, but if you're having to peg the gains, there's something else that needs to be taken care of
Jan Bennett
Old 08-31-2005, 09:06 AM   #6
_
not true!
gangsta rap only come from subs and 6 tweeters....no mids what-so-ever and more tweets are betta YO!
Jan Bennett
Old 08-31-2005, 01:32 PM   #7
3onDubs's Avatar
--Thanks a lot Red, kdunn, and Shotty, I'm not sure if my amps have preouts though cuz I cant get to them until I take out my rear seat (audio guys had fun with my car)...but I know I'm running the newer 5 channel kenwood excellon amp to my speakers (only using 4 channels) and the previous model 2 channel kenwood excellon 1600D amp to my subs (the one with the color changing fiber optic thing on the front)...
...this is starting to sound more complicated than I thought...I really don't care about surround sound, so much as I get the same sound quality that I'm getting right now...I'm going to be swapping out my dvd player and flip up xplod screen (which I paid so much for)...
...One last question: My car battery is in the trunk...so Install should be pretty easy, but do you guys have a power cable going to your monitor, or does it feed off the carputer's power supply...if so, how do you get it to do that?
Wiring 3 amps from a pc sound card! ldjones48 Car Audio 3 04-18-2005 04:02 AM
will the opus 150 power my system? I have all the figures intense Power Supplies 13 04-15-2005 03:55 PM
Wiring Diagram of Inverter and AMPS. Will this work? wonderworm Power Supplies 2 09-14-2004 06:15 PM
sound system wiring advice and componant choices for a newbie dbzeag General Hardware Discussion 0 08-27-2004 07:44 AM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
