now ive always considered blaupunkt to be quite good, am i right?
Velocity VD504 (cant find info on blau site.)
Technical features
# Max. total power (4 ohms) 4x100W (4-channel op.)
# Max. total power (4 ohms) 2x300W (2-channel op.)
# RMS power (THD@ 0,07 %) (4 ohms) 4x50W / 2x150W
# RMS power (THD@ 0,07 %) (2 ohms) 4x80W
# Channels 4/3/2
# Frequency response 20-20.000 Hz
# S/N ratio dB/A > 95 dB
# Total harmonic distortion 0,07 % (@full rated power)
# Input impedance > 20 kohms
# Gain adjust 0.3 - 8 V
# Load stability 2 ohms (4-channel op.)
# Variable low pass filter 40-160 Hz
# Variable high pass filter 40-600 Hz
# Subsonic filter 20-55 Hz variable
# Bass boost + 15 dB (45 Hz)
# Inputs 4 x Cinch/RCA, gold-plated
# Outputs 4 x speaker, gold-plated,
# Preamp-Out 2 x preamp out, gold-plated
# Power-on LED/protection LED blue/red
# Heat sink chromium-plated & engraved
# Dimensions WxHxD (mm) 465 x 58 x 278
is that any good? its £150 for it and im considering getting 2.
basically need an amp to power front L, front R, rear L, Rear R, Centrex2 and sub(2 channels bridged).
