The MP3car.com Store
Thread Tools Display Modes
Old 10-24-2005, 08:15 PM   #31
crsseyednsmilin's Avatar
Vehicle: 2005.5 VW Jetta 2.5L
My Photos: (0)
Quote: Originally Posted by Snootch
You can use that adapter. The one he linked you to attaches to the harness, not the radio. Those bare speaker wires would be the ones you would use for the speaker level input to your amp. Also, you might want to look at using a line output converter. There usually used to convert speaker level output of a factory radio to RCA signal level. Possibly they can be used backwards? Then you wouldn't need to cut up any wiring. The signal flow would be: PC--> 1/8" stereo to RCA cable--> Line out converter--> Wiring harness--> car wiring--> factory amp. Also, you may want to look in yout manual for some sort of remote turn on lead that the factory radio used to turn the amp on.
Thanks for the info! Ill look into this asap. The manaul dosent say bologna about the amp. Im sure the amp is turned on when power is comnig from the headunit to the cars computer. That sends a signal to the amp via the can-bus to kick in. Im wonder if I can give the can-bus line a little jolt and wake the thing up? Im not really sure what CAN-BUS line is or how it works. It just looks like power line to me.
2005.5 VW Jetta 2.5L, 1957 VW Beetle Custom
Previously Owned: 2000 VW Beetle TDI, 1982 VW Vanagon Westfalia, 1971 VW Super Beetle
My VW Jetta mk5 Carputer
frodoplayer.com
mk5 OEM NAV Skin - Frodo - In Progress
crsseyednsmilin is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 04:31 PM
Troubleshooting: NOISE Red GTi VR6 Car Audio FAQ 0 03-26-2005 10:31 AM
lengthening fm transmittor antenna wire hand General Hardware Discussion 2 03-24-2005 10:21 PM
FS: 3-way Components, Sub, Amp, and Wire! Sandstorm Classified Archive 26 12-10-2004 12:10 PM
where to buy wire to run from battery to inverter? hud Newbie 37 05-17-2004 07:01 PM
Sponsored Links
Ad Management by RedTyger
