09-04-2005, 11:13 PM
#1
1/8" Audio Out to Speaker Wire?
I tried searching but this seems to be a hard one to pull any relevant threads up on due to wording...
My 2005.5 Jetta already has a nice 8-channel amp integrated into it and I would like to see if it can work with my pc...
but Im not sure how to go from an 1/8" Audio Out to the Speaker Wire or if it is even possible.
I need to go from the Audio Out jack to:
Left Front +-
Left Rear +-
Right Front +-
Right Rear +-
Thanks in advance... yours truly... nOOb
09-04-2005, 11:21 PM
#2
is the computer's sound card stereo or quadraphonic? if it's stereo youll probably need y adapters. as far as the 1/8" out you just need cable with an 1/8" stereophone connector.
09-04-2005, 11:30 PM
#3
Its just a plain-jane audio out jack. So stereo.
If you could elaborate a bit that would be greatly appreciated. Especially concerning the connection of the + -. Im trying to go from the sound out stereophone jack to 8 wires.
I have a cable with a 1/8" Sterephone jack on one end and RCA red/white on the other. could I splice that and use it somehow?
09-04-2005, 11:46 PM
#4
Have a read of this - http://www.mp3car.com/vbulletin/faq-emporium/32430-how-get-sound-pc-car-stereo-amp.html
The computer out has 3 wires - Left+, Right+, and Common-
Your amp apparently has 8 input wires - Front Left+, Front Left-, Front Right+, Front Right-, Rear Left+, Rear Left-, Rear Right+, and Rear Right-
Connect the Computer Left+ to the Amp Front Left+ and Rear Left+
Connect the Computer Right+ to the Amp Front Right+ and Rear Right+
Connect the Computer Common- to the Amp Front Left-, Front Right-, Rear Left-, and Rear Right-
All you are doing is splitting the output to each input.
09-04-2005, 11:47 PM
#5
WOW ok. you can do this but youll get the same sound on two speakers.
ok youll need a 1/8" Stereophone connector. this is how i would do it.
If you get the connector here at Radio shack the package will elaborate on the 3 pins
09-04-2005, 11:50 PM
#6
In addition, you have may have to find connectors to suit. The cable you show is fine for the computer end, using the 1/8" Sterephone jack.
09-04-2005, 11:51 PM
#7
Ha thanks for the input guys... I appreciate it
09-04-2005, 11:54 PM
#8
crsseyednsmilin do ya understand all of this
09-04-2005, 11:56 PM
#9
Well I went searching on RadioShack.com for the connector youre talking about... and got like 500 results. So Im not sure about that.
Also... could I just cut open the RCA ends of my 1/8-RCA cable and splice the wires in that way? (PS which is the (-) on the RCA? In or out)
09-04-2005, 11:58 PM
#10
yeah you can splice it. and the outside of the RCA is the GND.
but beware, if the wire is fiber than you could be in trouble.
#11
Awesome... thats the route Im going to go then. Ill try and get this done soon and let you know of my results. Thanks a million!
09-04-2005, 11:59 PM
#12
I might be missing something but should tie Front & Rear Right + to Computer Right+ and Front & Rear Left + to Computer Left+?
From the way I read your diagram it looks like you are connecting Front Left & Right+ to Computer Right+ and Rear Left & Right+ to Computer Left+, which would have the left & right chanels assigned to front & rear.
09-05-2005, 12:01 AM
#13
Yeah, your right i got that confused!! thanks for noticing
09-05-2005, 12:02 AM
#14
No problem  It took me ages to try to work out how to explain it... almost as long as it took me to do it on my Probe...
09-05-2005, 12:04 AM
#15
yeah, its easy to do but hard to explain
| Thread Tools |
| Display Modes |
Linear Mode
