The MP3car.com Store
Thread Tools Display Modes
Old 09-09-2005, 09:57 AM   #1
P3rv3rt B3ar's Avatar
Vehicle: '99 c5 sebring silver vette "P3rvette"
My Photos: (0)
Your help needed!!!
Im computer scientist, but dont know s**t about car-audio.
So i could use your help to solve a problem.
My setup is Acer TM-C113 tablet, connected to cars headunit with FM-modulator, which takes 12V current. Everything works fine like that... but when i connect tablet to its own car loader (official acer product) i will experience huge noise on audio (its not just anoying, but its completely unbearable). could it have something to do with the fact that both (laptop and FM-modulator) are connected to same powersource??
Have u guys any suggestion what could i do... or do i just have to schedule my trips acording to laptop battery
P3rv3rt B3ar is offline   Reply With Quote
Sponsored Links
Old 09-09-2005, 10:01 AM   #2
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
do you experience the same noise if you are plugged into a wall jack? try it at your house, grab an extension cord and see if the problem still occurs... this will help us diagnose the problem.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-09-2005, 10:19 AM   #3
My Photos: (0)
Thanx man... ill go test that right away...
Old 09-09-2005, 10:48 AM   #4
My Photos: (0)
Ok i tried with laptop connected to wall socket... if i understanded u right, that was what u meant... and it worked like dream (well as good as possible with FM-modulator and factory head unit and speakers), not even anoying noise.
But note though... that i used different acer loader now (one meant for indoors use) since i dont have wall-socket-2-cigarette-lighter-socket-adapter available.
But anyway that means that laptop is not inherently unusable, so problematic component is either acer-car-loader or leaking car-powersource right?
Old 09-09-2005, 10:55 AM   #5
MySQL Error
scott_fx's Avatar
My Photos: (0)
i think you're correct.... so i guess the next step is to maybe try to hook up the acer-car loader to another car. and see if it still introduces noise into your car. make sense? basically we are just using car 'b' for a power source.
M10k
My Car Pc Install
Old 09-09-2005, 11:03 AM   #6
My Photos: (0)
Yes thats really good idea, sadly car b is 600km away right now but ill post as soon as i have change to test it.
If it turns out that acer's car adapter is faulty component... They better pray Allah, Jehova and Budha to avoid my wrath!
Old 09-10-2005, 10:34 AM   #7
My Photos: (0)
I had change to do quick car b-test today with friend car and it turn out that even though there was some noise it was totally different compared to using powersource in same car. Now i think question remains that is powersource of citroen xsara somehow "dirty" or does noise come from combined effort of both FM-modulator and car loader connected to same powersource... ill be experimenting with that as soon as have second car back in yard... however now i would already be interested what are my options on either possible case, cause todays test atleast prooved that tablet can be loaded with car loader same time it plays music.
So if the problem is caused by cars powersource... is there somekind of stabilizers for that? or how could i remedy situation?
And if its caused by combined effect would similar kind of solution do? or should i load trunk with batteries and so use different circuit to load lap and if i do that would it be easy to make cars loader to load those extra batteries too? like i said, i dont know anything about car-hifi
Old 09-11-2005, 02:23 PM   #8
numbers's Avatar
My Photos: (0)
Was car b running during the test? If not, and there was noise while using car b and not while using house current, something is almost certainly coming from the car power adapter. Of course, none of this is valid if car b was running... if it was, try without the engine running.
numbers is offline   Reply With Quote
Old 09-11-2005, 05:17 PM   #9
My Photos: (0)
Actually i dont remember to be sure... but i think car b was running. However noise was small... not near or above painlevel like when i use power from car a. But ill run car b test soon again just to confirm this.
Old 10-12-2005, 03:21 AM   #10
My Photos: (0)
Solved problem by installing extra battery.
Just letting u know, so that nobody waste time to post on solved issue.
Sponsored Links
Trackbacks are Off
Babysitter needed dos4who? Off Topic 15 10-22-2005 08:50 PM
ITPS Needed? Jeremyvnc Power Supplies 4 09-01-2004 09:38 PM
Amplifier Needed? c0rrupti0n Newbie 7 03-15-2004 03:04 AM
My project for the day - advice needed ddt General MP3Car Discussion 2 12-02-2002 07:51 AM
electronic Guru's needed ... felix99 Power Supplies 15 11-21-2002 09:46 AM
Sponsored Links
Ad Management by RedTyger
