Subs taking the input from the rear speakers? Never heard of that...sounds like a crossover type thing. BUT IMO you are either misinformed or someone wired the Scion strangely.
Where are you outputs from the Mini coming from? PCI card or what?
And with that question comes, where is the output from the MINI that is labeled SUBWOOFER?
You say you have it connected from MINI --> Amp thru RCAs
Is that just a pair? One left one right? Or is it dual pairs Front left/right, Rear left/right?
Either way you have NO subwoofer output as far as I can see from the MINI or the AMP?
A 4 channel amp will only power your 4 speakers, YOU CANT RUN SUBWOOFERS FROM YOUR SETUP!!!!
Where do you expect the subs to get their signal from?
Sounds like you need to power the subs FROM the AMP, meaning you need a seperate SUB channel on the amp...do you...no.
Subs need power, and you arent giving it to them.
Either run the rear channels of your amp to the subs and split the front 2 channels into both front and rear with a y-cable. OR buy a seperate mono amp for the subs.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
