Old 10-07-2005, 02:05 PM   #1
fortressgame is on a distinguished road
USB radio tuners?
i have a hauppage wintv usb 2 TV/radio tuner, and its horrible. DOesn't work with Windows Media CEnter, and they suggest I use their Radio32 application which doesn't work with a touchscreen. The buttons are tiny.
I want to replace this hauppage stuff.
What USB alternatives are there for getting radio, especially that work with Media Center Edition?
fortressgame is offline   Reply With Quote
Old 10-07-2005, 02:35 PM   #2
Moneyfink's Avatar
Moneyfink is on a distinguished road
are there any radio tuners that you can connect an external antenna (IE your car antenna) to?
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline   Reply With Quote
Old 10-07-2005, 03:52 PM   #3
Zip-Lock is on a distinguished road
That’s the holy grail my friend. Nothing is really good right now in terms of good radio reception and a good antenna interface. Things are in the works just be patient. Good things are on the way.
Zip-Lock is offline   Reply With Quote
Old 10-08-2005, 01:50 AM   #4
Raw Wave
rando's Avatar
rando is on a distinguished road
What do you have cooking Nat? Inquiring minds want to know!
2004 4runner
rando is offline   Reply With Quote
Old 10-09-2005, 08:06 AM   #5
ayasystems is on a distinguished road
I am looking for USB FM tunner too. If you find it please tell me.
Thankyouu
ayasystems is offline   Reply With Quote
Old 10-09-2005, 03:36 PM   #6
fatmidget is on a distinguished road
DISCLAIMER: I haven't checked if this product was discussed before, so my apologies if it was
I've found something like this a while ago when I was searching for carpc components.
You can find the product's page here:
http://www.radio-xtreme.com/
For people in Europe wanting to buy one you might want to check out
www.modguru.nl (dutch webshop, is apparently mostly in Dutch though)
A quick scan over the specs reveals that it comes bundled with Radiator, the remote control that comes with the device is programmable and the tuner is a digital one.
I don't have any technical knowhow on these things and I haven't ordered one yet, so I can't talk about the quality.
Once I've ordered, received, installed and tested it, I will give a quick review. (might take a week or two)
Maybe if anyone with some knowledge of these things can look at the specs and let us know what he thinks about it, I would really appreciate it
fatmidget is offline   Reply With Quote
Old 10-09-2005, 03:53 PM   #7
TyBong's Avatar
TyBong is on a distinguished road
Ive got some D-link USB radio, the app that comes with it is decent, bigger butons, etc. My old *** dlink has a RCA connector right on it, I havnt put it in my car yet, but past uses it worked pretty decent, I just soldered some decent coax on an RCA end, it worked great.
MORE COWBELL.
TyBong is offline   Reply With Quote
Old 10-19-2005, 02:16 AM   #8
TheNewJimJones's Avatar
TheNewJimJones is on a distinguished road
Okay, brainstorming time... My car came with this little 2"-3" deep radio reciever and separate tape deck. It has factory harness outputs and a car antenna in connector. I know my electronics and all that jazz but i was wondering if there was someone else out there that has a bit more electronics engineering experience than i do and thinks that they could fabricate other radio recievers similair to this to be compatible with a carputer. I ahve not had the chance to take the radio apart but since it powered the interior speakers when the car was stock i'd imagine it has a built in amplifier. Would there be a way to eliminate this amplifier and run the direct radio output to the carputer and still maintain the external radio controls? I want to eliminate my alpine head unit but still want a good radio. I'd imagine i could just add a connector and pass the radio signal throuh the line in, or maybe even if there was a way to connect it via USB? But id imagine someone would need to develop a driver for that. If you have any thoughts on this please post =)
TheNewJimJones is offline   Reply With Quote
Old 10-20-2005, 02:53 PM   #9
VWDash is on a distinguished road
I saw this one on a Mac PC its called the radio SHARK from griffin. Its USB no extenal PSU and has an antenna jack. http://www.griffintechnology.com/products/radioshark/
Im still in the planning station of my CarPC so I have not bought it yet but it looks good.
VWDash is offline   Reply With Quote
Old 10-20-2005, 03:43 PM   #10
Moneyfink's Avatar
so who's gonna integrate the controls for this into frodoplayer
My NEW carPC
Old 10-20-2005, 07:34 PM   #11
agentloveless's Avatar
agentloveless is on a distinguished road
Do car antennas have a single wire leading to them typically? or is it two?
agentloveless is offline   Reply With Quote
Old 10-21-2005, 03:35 AM   #12
Vchat20's Avatar
Vchat20 is on a distinguished road
ok. lets try to clean up the clutter here. first off, EVERYONE please first. most of what you have mentioned has already been posted elsewhere.
ok. now to explain some of this. first off, most of the currently available radio tuners designed for pc/mac use have really crap reception compared to a standard headunit. so if your headunit brings in your local station pretty well with some minor static here and there, expect to get constant static mixed with the music and mono audio. thats the best case scenario.
the Radio X-treme posted above: all i know is that David (developer of the frontend Centrafuse. check the frontend forum for more info) owns one and has had plans from the start to have it fully integrated in CF along side support for other tuners using the Radiator program. this of course doesn't answer for other frontends, just mentioning that there is another user here who may or may not have had good luck with it. i personally haven't been able to get any evidence as to its reception quality.
the D-Link usb radio has gotten some decent reviews from other users here. one good bit of news is that i have heard that hooking it up to your car's antenna is pretty painless sans some basic soldering and wiring and whatnot. it may or may not get good reception, but again: nowhere near as good as a standard headunit.
the radio shark really has nothing going for it. all I've heard is JUNK. crap reception. crap software which is proprietary. no radiator support (which most frontends rely on iirc). avoid it at all costs.
now that thats out of the way, i do want to point out that there is a homebrew tuner in the works right on this very forum which is being built specifically for the carpc community. with this in mind, its being built with parts that were designed for a car environment (mainly the tuner itself and other closely linked chips) so its going to have headunit quality reception. Also it has already been slated to have support for AM/FM/ and RDS (in-stream data such as song info, station call letters, weather, etc. broadcasted from the station to your radio which is then displayed on the headunit) functionality whereas past and current pc radio setups have just had FM capability and nothing else. needless to say, this IS the holy grail (that is unless Zip-Lock wants to get a few words in here on that ) for carpc radio. and before you post more questions about this, please read atleast the first page of this thread before posting aimlessly into the night.
g'night all
Your everyday carpc geek and tech guru at your service. *bow*
Vchat20 is offline   Reply With Quote
Old 06-16-2007, 05:44 PM   #13
tilma800 is on a distinguished road
What is the current status in the USB-radio world?
Last time I checked the HQCT was the best you could get, so I got it but never had it completely installed. I did not get a good noise free sound from it yet.
Are there better alternatives for it now?
tilma800 is offline   Reply With Quote
Old 06-16-2007, 08:08 PM   #14
HIPPOhifi's Avatar
HIPPOhifi is an unknown quantity at this point
Agree reception is terrible, good interface with Road Runner, but that dosn't help if all your hear is static. Even with an external antenna...
HIPPOhifi
HIPPOhifi is offline   Reply With Quote
Old 06-25-2007, 11:53 PM   #15
darag2358 is an unknown quantity at this point
Well, since it seems this thread is being resurrected, what's the verdict on the RadioShark 2? Is the reception any better and how's the external antenna interface?
darag2358 is offline   Reply With Quote
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
Radio and Tv usb card CdRsKuLL Road Runner 6 04-21-2005 06:18 PM
D-link Usb Pc Radio Dru-r100 mick-uk General Hardware Discussion 4 03-20-2005 05:31 PM
D-link USB radio - echo Rs! MediaCar 2 03-10-2005 03:33 AM
PCI Radio card better than USB?? xtreme_db General Hardware Discussion 0 09-01-2004 11:27 PM
