Old 10-15-2005, 01:30 PM   #1
pdjafari is on a distinguished road
AMP wont turn ON!! HEELP!
Hey all,
I have been having a problem installing an amp in my 04 G35 coupe. I cannot get the amp to turn on to save my life, the POWER LED at the top will NOT come on. Now the amp is a POS Profile California 400W amp and my HU is the stock Bose premium audio. I currently have an LOC to convert the signals to RCAs for my amp. I have triple checked my power line and I KNOW it has juice (the old tap the body and spark=power trick...). The ground is also secure, to a bare metal spot in the trunk (attached to a body panel). The remote however has been tough. The question I have is if I have a secure power/ground should my amp STILL turn on, even if the remote wire is NOT connected or not connected to the correct remote device?? OR is my problem the remote wire?? I am trying to determine if my problem is a bad ground or remote. I had always assumed that an amp should still turn on even WITHOUT a remote wire being connected.....I have been messing with the ground wire thinking even without a remote my amp should turn on. If you guys think its my remote I'll try finding a proper source for it and only troubleshooting that.
In addition what else can be used as a remote wire instead of taking a signal from behind the Bose HU harness?? Its a pain to remove all the dash panels and replace for one lousy wire...can i tap my cig. lighter?? (cig lighter only comes on when cars on....)
THANKS!!
pdjafari is offline   Reply With Quote
Old 10-15-2005, 08:43 PM   #2
pancit175 is on a distinguished road
Unless specified by the manual for the amp, you cannot assume that the amp will turn on without a remote wire hooked up. Most amps dont function without a remote wire. You should hook up the line to a switched(with key "on") and fused line. The cig lighter may be a place to do so, but i'd like to go to the remote line behind the radio with a fuse inline whenever possible, ideally with a relay because some of those lines are not equipt to handle much current. Also to avoid any amp thump/pop when turning on the amps out of sequence of the radio
PROGRESS:
pancit175 is offline   Reply With Quote
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
Use relay to tun on amp? Stealth97 Car Audio 7 06-25-2005 11:32 PM
amp pop dan__wright Car Audio 6 06-16-2005 05:24 AM
Wiring, fuse, amp, relay questions Vee24 General Hardware Discussion 7 05-25-2005 08:03 PM
Can Opus 90W remote turn on AMP and LCD > Gibbon Power Supplies 2 10-16-2004 09:57 AM
