Old 10-17-2005, 06:25 PM   #1
Merzbow is on a distinguished road
USB bus bandwidth and USB sound cards
Just a tip... USB bus bandwidth is more constrained than you think. I had my USB soundcard on the same USB hub as my USB hard drive from which I serve MP3s. I was wondering why my CPU usage would shoot to 50-100% during heavy sound. Well, I plugged the sound card directly into its own USB slot on the PC and CPU usage dropped way down. Apparently calls to the sound APIs in Windows would block synchronously waiting for I/O to be transferred to the sound card on the overloaded USB bus.
Merzbow is offline   Reply With Quote
Old 10-18-2005, 01:55 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
USB 1.1 or USB 2.0?
And it's been known for some time that USB sound cards pas function calls off to the CPU, hence driving up the resources used. This isn't anything new.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-18-2005, 03:34 AM   #3
Quote: Originally Posted by DarquePervert
USB 1.1 or USB 2.0?
USB 2.0. I wonder if I shouldn't have bought the firewire version of the IDE 3.5" drive bay I installed, my Xenarc does have a firewire port.
Old 10-18-2005, 02:13 PM   #4
Vero is on a distinguished road
USB 1 and USB 2.0 both have the exact same bandwidth. USB 2.0 just uses a higher compression rate. Firewire does have a much higher bandwidth and will give you lower latency and better overall sound quality.
however you just cant argue with a good solid PCI card. i personally will be using my M-audio firewire 410 to run my audio off my mac mini, just as soon as i take delivery on my new car.
Vero is offline   Reply With Quote
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
USB Bandwidth Question - PCMCIA card to USB 2.0 timwiththebo General Hardware Discussion 1 07-09-2004 04:47 PM
USB Bandwidth Problems??? Altimat Software & Software Development 7 04-19-2004 06:20 PM
USB Soundcard Woes phc General Hardware Discussion 7 02-11-2004 06:02 PM
