Hmm... I had foam under my computer, "trying to absorb shock" since it was mounted at the worse possible location: over my rear wheel.... Got a good amount of freezes over potholes... (mounted horizontal HD)
Then I changed the harddrive to vertical... about 80% improvement...
now I bolted the carpc strongly to the car itself, no more "lag" movement, it is completely solid... not one crash/skip in 2 weeks...
If you have it bolted on, the sub might be vibrating the air around it, but the HD/carpc is not going to move at all (I really dont think that the vibration will be able to get through the HD casing and such) since it is bolted...
If you put it on foam or whatever, it will not be 100% solid, and will vibrate as well as the air around your subs = worse...
so IMHO all this "foam it up", "it will be crap if you bolt it to the car", yada yada, is all non-true speculation... at first through, foam should "cushion the sub-pounding", but it is best to have the carpc bolted without independent movement from the car (the sub isnt pounding the entire car so there will be less movement by bolting it strongly to the car)
Roy
2005 Range Rover 4.4
