The MP3car.com Store
Thread Tools Display Modes
Old 10-19-2005, 11:47 PM   #1
3onDubs's Avatar
Vehicle: 2004/BMW/325i
My Photos: (0)
Too much bass for my pc case?
I'm just starting to get all of my pieces together and I have an issue...currently I'm running a kenwoon excellon 1600 class D amp to two competion 12" orion subs. These suckers push out a lot of bass...enough to cause my roof to physically vibrate when looking from the outside. So here's my install question....
...where should i put the carputer? Is it ok to leave it in the trunk, or am I running a risk of damaging the pc? I've seen many installs with the pc in the trunk along side the subs. (im using the ampie case by the way)
3onDubs is offline   Reply With Quote
Sponsored Links
Old 10-20-2005, 06:20 AM   #2
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2006 Renault Megane
My Photos: (0)
You should be fine...based on the fact that no one reported a problem like this as far as I know.
Epia M10000
Travla C137
Opus 150W
7" MM400 V2 Touch Screen in Custom Dash
7" MM400 VGA Monitor
7" Monitors in Custom Headrests
Slim DVD
BU-303 GPS
iDrive Griffin Powermate armrest
USB Wireless LAN
Cris is offline   Reply With Quote
Old 10-20-2005, 07:18 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Actually, someone did, but I don't think it was the vibration from subwoofers or the magnetic field from the bass that caused the failure.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 10-20-2005, 08:11 AM   #4
XxAndyxX's Avatar
Vehicle: 2001/Pontiac/Firebird
My Photos: (2)
I have 2 12" Avalanches (comparable to brahma and XXX). I have 2,500wrms going to these monsters, and they get loud as hell. Loud enough to distort your voice when you try to talk. They are aiming right at my CarPC, and do not affect it at all.
XxAndyxX is offline   Reply With Quote
Old 10-20-2005, 08:58 AM   #5
Tainted Love
Cris's CarPC Specs
Cris's Avatar
My Photos: (0)
See...!
Epia M10000
Travla C137
Opus 150W
Slim DVD
BU-303 GPS
USB Wireless LAN
Old 10-20-2005, 09:41 AM   #6
3onDubs's Avatar
My Photos: (0)
Thats what im talkin about...thanks guys. It's so much easier to mount in the trunk anyway cuz BMW's have the battery in the trunk along with my amps....i wont need to run any audio wires to the front, will I? If i don't, then will my radio harness (that is connected to my aftermarket HU) just be sitting there?
Old 10-20-2005, 09:55 AM   #7
StrataG's Avatar
Vehicle: '03 GTI 20th
My Photos: (0)
You would not be using your harness for anything in most circumstances. If you wanted anything to turn on with the accessory position on your ignition you could wire it up to that. It also has power leads, so if you wanted to use a small regulator up-front for say your screen/dvd drive you could hook them up to that instead of running new wires. If you don't use it for anything, just use a zip-tie or something to hold it in place so it doesn't knock around in your dash just as a precautionary measure.
StrataG is offline   Reply With Quote
Old 10-20-2005, 10:15 AM   #8
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
I'm going to say good luck... I don't think It'll last long. Are you using a normal HDD, laptop HDD or solid state media?
I just think you'd really be beating on that harddrive with the vibrations... What if you took some dynomat and put it around the pc case to dapen some of those heavy vibrations ?
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 10-20-2005, 10:18 AM   #9
Vehicle: 1997 BMW 328i Convertible
My Photos: (0)
Hey guys,
I had been wondering the same thing as 3ondubs. I must say I'm very surprised that there's no issue between such rough electronics (magnetism, vibratioins, etc.) and a carputer. Looks like I've got even more to do now
bdrezner is offline   Reply With Quote
Old 10-20-2005, 10:22 AM   #10
3onDubs's Avatar
My Photos: (0)
I'm using a laptop HDD...Dynomat would actually be a good idea (i guess that rules out the idea of bolting the pc to my sub box)...i could probably even put a little piece of dyno on the back of the actual hard drive...not sure though...has anybody else mounted their pc next to their subs?
Sponsored Links
Old 10-20-2005, 10:51 AM   #11
StrataG's Avatar
My Photos: (0)
I wouldn't suggest mounting them directly next to each other. The magnets on high power subs are pretty strong and the vibrations will obviously be most intense closest to the sub.
I have my computer about 3-4 feet from my sub-box. So far I have had no issues, but I only have 600 watts RMS going to one 12". I rarely keep my volume even close to max and I especially doubt that you do as well. If you seperate them and keep the volume reasonable most of the time, I don't see there being an issue.
Old 10-20-2005, 12:16 PM   #12
3onDubs's Avatar
My Photos: (0)
That sucks...my whole trunk is pretty much my sub box...i think that i have about a little over a foot of space between my subs and the end of the trunk...subs are facing away from the back seats to utilize trunk air space...there are two pockets on the sides of the sub box also...but that would be too close to the magnets as well....hmmm....the problem is that i can't mount under either front seats because BMW seats have no room underneath for a pc (cant even stick my hand under there)...has anybody else had this issue? Has anybody mounted their pc close to their subs?
Old 10-20-2005, 02:59 PM   #13
XxAndyxX's Avatar
My Photos: (2)
Is 2 years long enough?
Old 10-20-2005, 03:33 PM   #14
My Photos: (0)
Is that how long your setup's been rolling? How far apart are your subs from the computer?
Old 10-20-2005, 03:41 PM   #15
3onDubs's Avatar
My Photos: (0)
Definitely long enough....but how much bass are you pushing, and (like above) how far are they from your comp? Any pics?
Sponsored Links
vB code is On
Trackbacks are Off
Painting Ampie Case semovodka General MP3Car Discussion 2 10-08-2005 04:37 PM
Help with mounting PC case. Nodotus Fabrication 10 08-30-2005 01:11 AM
Question about ITX-PD/3677 and 3688 DC Deck PC Case m3rdpwr General Hardware Discussion 2 12-21-2003 07:47 AM
Book PC case FreznoSmooth General Hardware Discussion 4 12-29-2000 11:10 PM
Book PC case FreznoSmooth General Hardware Discussion 0 12-16-2000 10:23 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
