Quote: Originally Posted by Gobby
Its an SPL AV035.1
Seems to be an eBay special. I haven't been able to find any information outside the figures you mentioned. Problem is without knowing the continual power output of the amp, it's a moot issue to provide speaker ideas. Your only choice is to go with speakers which can handle let's say 1/2 the power output as their RMS ratings. In reality though, this amp seems like one that is closer to the 1/4-1/10 RMS/Peak amps. You could wire it up and then use a multi-meter to figure out the power output.
In all honesty, I would stay away from this amp and return it if you can. If you decide to stay with it, maybe the manual will have more info. Outside of that, use my advice above.
