The MP3car.com Store
Thread Tools Display Modes
Old 11-01-2005, 03:02 PM   #1
Vehicle: 2005/Nissan/Altima
My Photos: (0)
My headless wiring dilemma
Hi, my application is for a 2005 Nissan Altima without the Bose system. I'm planning to stick an Xbox in it, which obviously has RCA audio out. However, my factory head unit doesn't have an AUX input, either on the front, or on the back for a CD changer. My first priority is low cost, and my second is a relatively clean install. My first idea was to just splice in the L and R channel RCA wires directly to the wire harness behind the head unit, and put in a switch to toggle between head unit and Carputer audio input. Upon lots of searching, am I correct in saying that this won't work? The Xbox's RCA audio outputs are line level, and the wire harness needs high level to go to the speakers? Or does it not matter? Even if I buy an amplifier with RCA inputs (which I'd rather not do due to cost) I certainly can't spend the money to upgrade all the factory speakers as well, which I'm told is a must to prevent blowout with a better amp.
I'm a noob, and I feel like I'm stuck between a rock and a hard place in terms of trying to get the audio in there without spending money on components I can't afford (amp, speakers) or ultimately won't need/use (aftermarket head unit). I've used FM transmitters with a portable mp3 player before, and I think they're a little low quality, even for my standards, which is why I'm not going that route. I don't mind getting in with wiring and solder, which is why I cringe at paying >$50 for what would essentially be an adapter. Any thoughts? Is it too wacky to think about finding where the cd player's signal meets the head unit, and splice in a stereo signal there, or is that all internal? Thanks in advance for any help.
Okita is offline   Reply With Quote
Sponsored Links
Old 11-01-2005, 03:23 PM   #2
arebelspy's Avatar
Vehicle: '99 Mustang Convertable
My Photos: (0)
Lay out the $100 for a decent headunit with RCA inputs and forget about the problem.. it will pay off in the long run in terms of hassles, etc.
-arebelspy
See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
Quote: Originally Posted by xdjxklusivex
i think every thread is now a whoreing thread
arebelspy is offline   Reply With Quote
Old 11-01-2005, 03:27 PM   #3
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
I've messed around with a lot in my car and have been pretty succesful at getting some hacks to work... But i've also ruined a lot of good working components as well, by expirementing.
You could get wiring diagrams from any Nissan Certified dealership that will tell you what every pin on the back of your radio does and probably solder up some rca jacks. With that said, I'd save yourself the time,money,research and possibility of screwing up and buy one of these: http://www.logjamelectronics.com/pie35rca6mm.html
This isn't an FM mod...
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 09-27-2006, 03:19 AM   #4
My Photos: (0)
That won't work his HU doesn't have cd changer capabilities. I'm in the same position he is in, the only thing I can think to do is get the BOSE HU but that doesn't help the money problem.
jrn6264 is offline   Reply With Quote
Old 09-27-2006, 01:12 PM   #5
Vehicle: 04 Honda Element
My Photos: (0)
Cant squeeze water out of a stone. If you don't have twice the budget that you think it will cost, than dont do it. I hate half assed jobs that wind up costing more than if you would have done it right the first time. I'm speaking from experience here
I modified my girlfriends Toyota Matrix radio. I located the wires which ran from the cd pickup mechanism to the main circuit board. I figured out which wires were the signal and spliced into them. Now you can insert a switch and an auxiallary input.
If you read that last statement and think, "Jesus, no problem, i can do that with my eyes closed becasue of all the electronics experience I have!" or "I'm pretty smart with electronics, but I can afford to blow the thing up and buy a new one if i mess it up too bad", then do it. If not, save some money for a while and do a lot of reading.
Will Albers is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Wiring Xenarc to wiring harness? deftones8769 Power Supplies 5 04-10-2005 09:07 AM
Headless Setup - Quick Amp Wiring Question. crosseye Car Audio 6 07-13-2004 02:18 PM
Inverter Wiring MoniraInc Power Supplies 10 06-25-2004 08:23 PM
datalux 4x20 red lcd wiring diagram? etrik LCD/Display 0 12-07-2001 03:35 PM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 02:11 AM
Sponsored Links
Ad Management by RedTyger
