Old 11-08-2005, 06:12 PM   #1
3onDubs's Avatar
3onDubs is on a distinguished road
Amp ground line = psu ground line?
Would it be ok to take all of my ground wires (regulator, psu, screens, usb hub) and run them into my 4-way amplifier's ground port...the amp is grounded to the chasis, so they will all share a common ground...?
...is that ok? is it recommended?
...how about the power? (both of my amps run to a capacitor which runs through a fuse to the battery)
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 11-08-2005, 06:31 PM   #2
tasteItheIvalue's Avatar
tasteItheIvalue is on a distinguished road
if by 4 way port you mean distrobution block, then yes; thats fine. I would make sure your ground wire is a decent size though. You can do the same with all your power wires. circuit city has some good tsunami power distro blocks (a little high priced though.) Just make sure your ground is thick enough to handle whatever power your throwing at it.
tasteItheIvalue is offline   Reply With Quote
Old 11-08-2005, 06:45 PM   #3
3onDubs's Avatar
I was actually referring to my amp itself...(i have two amps, a 4-channel and a 2-channel...i meant to say "channel" instead of "way")...but distribution blocks are mentioned a lot in power supply discussions...
Should i use a distribution block?
Would it be ok to just stick all of my ground wires into my amp?
Would it be ok to do the same with all of my power wires?
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 11-08-2005, 10:11 PM   #4
i wouldnt stick em in the amp. i would buy 2 disto blocks, all your power in one, grounds in another. sounds like your going to be drawing a lot of power from the battery so you might want to invest in some 4 gauge or thicker wire for the long stretch to the trunk, then split out to 8 gauge for all the amps/pc/etc. same for the ground. also... circuit city sells batter terminal connections that allow you to re-ground your battery to the chasis (may want to consider if your lights dim during deep bass).
Old 11-12-2005, 12:36 PM   #5
albysure's Avatar
albysure
using one common ground point is better
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
Powering up amp from the computer psu.. cyrofilho Power Supplies 12 08-10-2002 05:08 AM
PSU 12V issue Shades Power Supplies 2 05-23-2002 03:59 AM
Question: Arise psu: ground, neg, and pos.....? Tony S Power Supplies 2 05-02-2001 08:54 AM
