Old 11-08-2005, 08:10 PM   #1
azzurro is on a distinguished road
Who here tunes their car audio? Software for Time Alignment, EQ, Crossovers?
I came across an interesting article: http://www.diymobileaudio.com/forum/showthread.php?t=17
I would like to do some tuning... does anyone here have any experience with it?
Is there any software out there does time alignment? What about good digital crossovers and equalizers?
I'm running an Audgiy 2NX and would prefer to not buy an MAudio caard... even then I don't think that you can do time alignment with their products.
TIA!
'03 Intensa Blue Pearl Lexus IS300
Specs: Xenarc 700TS, Opus 150W PSU, CarCPU Case, 2.0 GHz Celeron D, DFI PS-35-BL, SB Audigy2 NX, Centrafuse 1.4
Progress: Car PC up and running!
To Do: Navigation, WiFi, AM/FM Radio, DVD
azzurro is offline   Reply With Quote
Old 11-09-2005, 12:59 AM   #2
arandall850 is on a distinguished road
I have also been looking for a good crossover program. I'm running an extigy and for now I have just been using an electronic MTX crossover. Time alignment I'm not too concerned about time alignment as i just use front kicks. EQ is easy ala winamp/roadrunner or other software. Even audigy drivers should have it.
arandall850 is offline   Reply With Quote
Old 11-09-2005, 07:23 AM   #3
SickVette's Avatar
SickVette is on a distinguished road
I do alot of tuning. I use an Audio Control RTA though. To have the most control over your system and maximize the tune you will need to have a 1/3rd octave eq and variable xovers. The xovers can be passive or active. Often I get a base setting on the xovers and do not adjust them after that. The eq is very important. A standard eq does not allow for fine adjustements....standard meaning indash 7 band and simular.
SickVette is offline   Reply With Quote
Old 11-09-2005, 10:16 AM   #4
Admin
gnomad is on a distinguished road
I'm not doing this, but I'd like to. ;-)
Given that high-quality, 8-channel sound cards are getting fairly cheap these days, it is not unreasonable to drive every speaker through a dedicated amp, without any external crossovers (passive or active) whatsoever. Even a low end machine should have plenty of power for a high-resolution EQ and time delay for each channel.
The best part is that you can auto-tune the system on the fly depending on conditions -- number and location of passengers, windows up or down, sunroof/convertible top open/closed, etc.
I started some Linux-based DJ software a few years back to move all the gear in my rack (EQ, compressor, active x-over, effects boxes) except the amps into the PC and this isn't all that much different.
All I need is the time to get back to work on it...
-p.
gnomad is offline   Reply With Quote
Old 11-10-2005, 02:10 PM   #5
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
you can get time alignment as well as x-over and eq adjustments if you are using the kxdrivers with your pci sb card. or you can get an auto time alignment if you use an external dsp like the alpine one i'm using.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 11-10-2005, 04:17 PM   #6
WhiteRabbit is on a distinguished road
everyone has their own preferences for tuning. some folks like to tune their mids first, some their tweets down. up to you.
I prefer to start with the crossover. I set everything fullrange, and play the drivers one at a time, turning down the cutoff frequencies till it starts to sound dull. that tells me the limits of every driver. then I go with the more conservative setting and set them equal betweet each set of drivers on both sides of the car. the more overlap potential I have, the more options I have when setting the actual usable crossover point in the car.
usually the steeper the slope, the better. But this is also subject to personal preference. shallower slopes integrate speakers together better, but in an envoronment we often separate the drivers far apart, such shallow slopes often create muddy localization and endless phase problems in the actual crossover region. most well tuned cars I sit in run the steepest slope they can get their hands on. Also its important to use the same slope between two drivers (example: tweeter highpass and midrange lowpass). using different slopes also change the rolloff characteristics between the frequency response just above versus just below the cutoff point, and it messes with tonality.
once you've got your crossover points set, you can work with phase if you want. I personally prefer my phase all equal, but I'm no world class competitor. often times using kickpanel locations the tuner can flip the phase of the drivers side midrange, and not need any TA/stageEQ!
from here, I tune my gains. with a zero bit track Ill turn my gains/volume as loud as I can without hearing any noise. this lets me maximize the potential volume of all drivers without any noise, ever. from here on out, my only noise problems are road noise.
of course, usually dong this means my bass is too loud, the tweeters are poorly balenced, etc. so I grab my radioshack meter and a pink noise track and play pinknoise through each one of my stage speakers and attenuate all gains individually to my weakest speaker.
I perform all this before I even THINK about starting to tune! By now, cymbals and other highs in center stage are usually above the steering wheel, and kickdrums in the center sound like they are far left.
here is where tuning starts to get very, very divergent. some folks dont believe in TA. some dont believe in using a stereo EQ to tune stage location. Some believe in neither! I recommend trying all three, so you can get a feel for it.
from now on, your two enemies are phase and tonality. if you dont believe in stageEQ-ing, you are going to use your TA if needed (not always needed) to get your drivers centered. if you have a tweeter with a very high cutoff point, you wont need to TA the driver. the time dependant nature of sound really only affects performance below 500 Hz. with a low cutoff point tweet (3000 Hz or so) some of those frequencies leak through, and you *may* have to apply some TA.
I had a paragraph typed up, but since there are multiple theories on fine tuning (all valid) I am going ot make subsequent posts on it so everythign is a little neater.
WhiteRabbit is offline   Reply With Quote
Old 11-10-2005, 04:18 PM   #7
accentsound's Avatar
accentsound is on a distinguished road
All in all as the main influence on such adjustements and tuning is Driver Placement. You pretty much have to do it when first installing the system. Even then you are limited by the loactions available to stick drivers.
After that it is pretty much a perception issue. And that is usually different for each individual. Oh you can use scopes and RTA's and test disks until you are blue in the face.
As many time as not what you hear can be at odds with what the instruments say. Tunig in such a manner is useful to get a system into the ball park. After that, it is sit in the car and tweak levels until it sounds good to you.
Dynamics change in a vehicle from a ton of variables. Temp, Humidity, How many people are in the car, windows up, windows down, AC on or Off. Groceries in the back seat etc.
While Auto TDA systems are cute toys, I feel that they are mainly expensive frills that do not live up to thier claims. Even if they did, the benefit of some thing that could only be measured by test equipment and not the human ear in a Automotive environment is for all purposes useless.
accentsound is offline   Reply With Quote
Old 11-10-2005, 04:25 PM   #8
whats interesting to note is that a computer can not be used to tune perfection. the best a computer can do is equilize gain, TA, and FR for all drivers to the listener's ear.
once the listener puts his legs in the footwell, FR changes. equilizing gain and TA puts the stage directly over the steering wheel, not over the center of the dash!
So, some people say the computer is a junk tool for tuning. and technically, they are right. youll always have to polish your stage by ear.
Im not willing to go that far yet. anyone here can computer tune their car using a program called "speaker workshop" and ANY microphone. since we are talking about a comparative analysis, we do not care about absolute FR, merely comparative FR.
we can take plots like this:
http://www.objext.com/semi/first,equalgain.jpg
you can see the absolute FR looks HORRIBLE. its the mic. doesnt matter, we just care about the comparative FR plots from left to right side. looks terrible still!
but we can continute to take farfield measurements till we get things a little more equal. (attenuating, NEVER boosting!)
http://www.objext.com/semi/second,eqadjust.jpg
we can also take time dependant measurements to get everything perfectly time aligned to the drivers ear.
all this computer tuning, and your stage sits in front of your face, rather than even with the dashboard oops!
its still a fun (free!) program, I recommend everyone try it.
Old 11-10-2005, 04:33 PM   #9
now, the bottom line, as said before, is phase and gain.
the key idea here for EQ tuning is the fact that gain AFFECTS phase! so we can push around instruments using an EQ!
parametric and graphic, that TOO is personal preference. I'm a parametric EQ guy. buddy of mine is a graphic guy. both our cars have sounded great in the past.
the idea is simple. once youve got your gains evened out, you play a sweep. in the car, itll sound like it sits directly in the center of the vehicle, where the proper stage can be. of course an untuned car, that speep is gonna move all over the place in the car. down low itll be REALLY drivers side oriented (remember, NO TA has been applied here) up high it could be anywhere.
so as the sweep is played, the EQ is adjusted in each band to shift the sweep to center. always attenuating, never boosting. once its been centered, the sweep is played again, and focussed even more.
using this method (and midbass WILL move around with enough gain change) you can actually tune a VERY focussed AMAZING stage without using TA at all, even using door locations!
using the computer, you can do the same thing, but itll be far, far, far less accurate than the sweep. I'm so glad accentsound chimed in about the fallacy of computer tuning.
But I invite everyone to read the technical papers of Dan Wiggins (president of Adire Audio) and Stephen Kephart, who are the main drive in my realm of experience behind gain/stage EQ tuning, without need for TA.
Old 11-10-2005, 04:41 PM   #10
every audio feature is linked. everything. you can test this yourself with speaker workshop, as you adjust TA, or adjust gain, you affect the frequency response. period.
I'm not so great a tuner yet that I know how to minimize sticking my hands into the signal to tune things in. as a result, I will probably never have a car that can take world finals. this doesnt mean I can't have an AMAZING sounding car.
TA can be a very usefl tool to push around lower frequencies. When I tune my TA, I like to use a track on the usaci disc titled "wishing well" by Michael Ruff. It has a kickdrum, bass guitar, and vocal track all dead center. So I have something that have widely varying frequency ranges, all centered. This lets me TA my kickdrum and/or bass guitar to center, without overshooting the setting, or changing the gain enough. not not enough, as the case may be!
you will end up with far less focus using this method versus the first, unless you take accentsound's advice about speaker positioning (which can have AMAZING resuts combined).
there isnt too much to be specific about here. I'm not an expert in this method of tuning, so the best I know is that its more than simply a "balence" between TA and gain settings. what is there more? no idea! someone else can chime in, hopefully will be more specific than "TA is used to compensate for unequal pathlengths from the same drivers to the listener position". I've certainly never been told more than that! doesnt help tuning, does it....
Old 11-10-2005, 04:46 PM   #11
I invite everyone to read this post:
http://forum.elitecaraudio.com/showt...hreadid=121086
last post on the first page talks baout getting the baseline before tuning, it makes things MUCH easier.
also take special note of the two responses on page three. might be an eye opener to some of the lock step accepted information in araudio these days.
and also
http://forum.elitecaraudio.com/showt...hreadid=120918
Old 11-10-2005, 07:06 PM   #12
SickVette's Avatar
White Rabbit...you make very good points and provide alot of useful information but please tell me how to check phasing. Phasing changes for the xover and then can change again from speaker location. I remember Rockford Fosgate had a tool available that told phasing and I think Autosound 2000 also had one. But I have never used it or seen anyone that has.
When setting up a car for SQ there are three things to keep in mind from the start...speaker position, speaker position, and speaker position. Speaker position will make or break a system in an instant. Speaker placement has an effect on staging, sound quality, and how much adjustement will need to be made in the EQ. Properly placed speakers will need very little adjustements in the EQ or TA. Here is a little story about speaker placement. Around 10 years ago I was working at shop that had several IASCA competion vehicles to our credit. My job was make sure they all sounded good first and looked good second. After spending three hours doing speaker location set up I handed the car over to the other installer at the shop to make the kick panels. The car was near perfect, a little tweaking and it was on the money. The installer building the kick panels decided the speaker on the passenger side was not attractive or linear to the driver's so he moved it. Needless to say the car lost it's next competetion and the installer almost got canned. On the flip side not everyone or every car can have excellent speaker locations so we must rely on adjustements through EQ, xover, and gain.
Accent...I do agree with you on auto EQ's but not on RTA's. It is IMPOSSIBLE to fully tweak a system without a RTA. The RTA gives you a base line ... a starting position. Then it goes to ear. When I tune I switch back and forth between ear and RTA many times. Making a car sound good is not all that difficult....making it win is a different story. Ofcourse very few of will ever compete to that level but it is always a good idea to approach the project as if the car is going to IASCA finals.
Old 11-10-2005, 07:53 PM   #13
Im not sure how to measure phase. the tracks you are referring to are a general test for left versus right phase, and only compare fully in phase to fully out of phase. not the best tool in the shed! but important none the less. I usually employ that track to make sure I am on the right track, rather than actual reference material. sounds like you dont need it as a reference, either
and there were several vehicles that went to world finals from team lotus, most tuned by the man Dingaling, all by ear, no RTA, no computer. Team Lotus did very well this year, too.
the only thing RTA gives you is a good score on the RTA. Everyone I've ever talked to agrees that a flat frequency response in the car sounds like poop, and I've seen the same myself.
Speaker positioning affects unmeasurables, such as depth, height, and width, much much moreso than tonality or image. And I absolutley think its paramount to a competiton car. There will always be something lacking in a car that has crystal clear imaging, but no depth. Or a car always sounds tinny to me when the stage is super narrow. even if the tonality of individual voices are rock solid.
and certianly no EQ can compensate for poor positions.
But at the same time, RJ took a wrx sti to world finals, with his 2 way mids in the doors, and his large format tweeters midway up the pillars (talk about an aesthetic nightmare!) and took second place. His car sounded amazing. so it CAN be done, and I would hate to suggest to everyone here that it is abolutely neccesary to run kickpanels and have their speakers meticulously aimed OR ELSE its gonna be a poopy sound!
Old 11-10-2005, 08:53 PM   #14
Guys, thank you very much!
I now have a lot of excellent info to work with when beginning my tuning adventures I have no experience yet so I can't really contribute to the discussion in any way.
Because we all have computers in our cars, I thought it would be very natural to use to your computer's processor to do all the DSP work (TA, XOver, EQ).
What would you recommend? Scott_fx recommended kxdrivers, but these will not work with my external sound card.
Has no one written any software that will work well for this? I'm pretty sure that I can find quality filters and EQ with a bit of digging, but what about time alignment?
Will I need to use an external processor?
I was kind of hoping that there would be some quality free (or even pay) software available. I've got the computer in there... might as well use it. I'm adding a sub soon, which means another amp, and not a whole lot of space for an external processor.
Old 11-10-2005, 09:42 PM   #15
SickVette's Avatar
Personally I use external eq's and generally stick with the passive crossovers the speakers come with. I am goint to use an Alpine PXA H701 in my car and use the digital output from my external sound card. For me it is easier to stick with what I know. But I do find it a bit strange there is not alot of software available to do the same thing. I have meet people in the music industry that have software based eq's but I have never seen the software for sale. I would like to find something I can edit MP3's with. Please post up if you find something.
audio interface (direct comp-> car audio sys) Noble Newbie 5 02-29-2004 08:18 PM
Experienced PC guys needs Car Audio Primer SwapMeet Newbie 6 02-10-2004 05:33 PM
favorite car audio install information sites? fluffy2097 Off Topic 4 11-22-2003 01:07 PM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 11:27 PM
Connect hand held MP3 player to car audio system? jasonwood General Hardware Discussion 3 10-31-2001 12:30 AM
