Quote: Originally Posted by StrataG
Is it consistant every 10 seconds? If it is consistant, it is likely some kind of software issue. If it is not, could it be that when reinstalling your system you didn't make a tight connection somewhere? More specifically the remote line to the amp? If it is not a good connection it is possible that you are constantly resetting the amp around turns or on bumps.
Yes. It is every 10 secs when it happens. It starts when windows is at last 2% of completing bootup from hibernate. It also starts at the end of boot process if it is coming up from a complete shutdown. I have checked the connection an found it to be good. My remote connection to the amp from M1ATX is not that good but i am going to change that soon. Interestingly, no thump in last two days.
To Canuck: I don't have a Car amp that has optical Input. I was trying to get digital sound and use it as a HTPC box.
