Old 11-12-2005, 04:37 PM   #1
NateDawg99 is on a distinguished road
Unhappy Problem with Peripheral Aux2Car for Trailblazer
I bought the Peripheral Aux2Car Auxiliary Input Interface for my mp3 player (not ipod) in my 2004 Trailblazer. I installed everything correctly but pressing the CD/Aux button did not work. If anyone has had a problem installing this in a trailblazer and found an answer please help!
NateDawg99 is offline   Reply With Quote
Advertisement Sponsored links
Old 11-13-2005, 12:11 AM   #2
SickVette's Avatar
SickVette is on a distinguished road
Did you have to hard wire it or did it come as a plug and play unit? I am guessing you are just using it as a RCA input? Do you use MSN messenger...I ask because if you get on Messenger on Monday I should be able to get you an answer. I have several friends that work for Peripheral.
SickVette is offline   Reply With Quote
Old 11-15-2005, 09:09 PM   #3
it was basically plug and play i unplugged the cd player and put a connection between it that is read as a cd changer. I did have to sauter a wire for power to the cigarette lighter and I tested it for 12V. My msn messenger name is natedawg99. Ill try to be on some time just add me and message me if im on.
Old 02-09-2008, 08:52 PM   #4
robself705 is an unknown quantity at this point
I have the EXACT same problem!! What was the solution??!!! THANKS
robself705 is offline   Reply With Quote
Old 02-13-2008, 06:34 PM   #5
black_mamba is on a distinguished road
Did you guys figure this out? I had a very similar problem using a PAC AUXBOX on my 07 Uplander. It did not work in a 05 Uplander either. I believe both units may be the same.
PAC's:
http://www.pac-audio.com/products/pr...iliary%20Input
(2nd to last)
Peripheral's:
http://www.peripheralelectronics.com...arch=aux%20box
Anyway, it would not work no matter how I set the dip switches. My OEM stereo has the AUX button and I do not have OnStar/XM.
black_mamba is offline   Reply With Quote
Old 02-13-2008, 09:17 PM   #6
I actually am using and AUXBOX too. I contacted PAC and they said to exchange it. Im doing so right now. I really hope that its the box that is defective because I dont want to mess with this much more. Ill post as soon as I try the new unit.
Old 02-28-2008, 06:47 PM   #7
Well, bad news. I installed the exchange and no luck. It seem like when I hook it up to the power, the dash turns off and so does the radio and when I unhook it they turn back on. I dont know whats wrong. I am going to contact Pac and see what they say.
Old 03-01-2008, 06:25 PM   #8
Success, I got it to work, but had to set the box for XM mode. The stereo would not pick it up on redgular GM Class 2 mode. I hope this info is of help to some one.
A little problem with my car... Maybe... BoyNextDoor Power Supplies 30 11-13-2004 09:58 PM
MedicaCar Volume Problem -- Need Help BrUTaL MediaCar 1 11-09-2004 09:27 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
Media Car not responding... Lilliput problem? carpcnoobie MediaCar 3 09-01-2004 02:38 PM
