Old 11-21-2005, 12:24 PM   #1
3onDubs's Avatar
3onDubs is on a distinguished road
Panasonic CY-AC300 DSP
I am planning on upgrading my current setup by throwing this in the mix...I have read up on all of the posts shedding light on the digital route and I feel that this is the way to go...I just had a question that I couldn't find an answer to...
It has been implied by most of the people that are using this DSP, but never mentioned....can this DSP be used with non-digital amps? If so, does this defeat the purpose, or will I still get an improvement over a soundcard?
Also, If I use the Panasonic DSP, will I need a line driver since my soundcard has very low outputs, or will the Panasonic amplify the signal on its own?
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 11-21-2005, 03:48 PM   #2
peterh is on a distinguished road
When u say "can this DSP be used with non-digital amps?" u mean amps that take analog input? if thats the Question then yes. This DSP outputs 6 (5.1) separate analog channels (RCA) ONLY so u use amps with analog input.
No need for a line driver if u use the Optical SPDIF (TOSLINK). I don't know if u need one if u are going to use the Analog input(2 channel).
I have this DSP and i plan on using it's Optical input and connecting it to the Turtle Beach Audio Advantage Micro 5.1 . I don't want to use bigger sound cards or an Digital RCA to Optical converter
peterh is offline   Reply With Quote
Old 11-21-2005, 04:39 PM   #3
3onDubs's Avatar
Ok, so if I have the soundblaster live usb soundcard (with an optical out), then I can use this to input into the DSP. Otherwise, if I went directly from via's onboard digital RCA out, I would have to buy the converter....i see.
Do you know if there would be any sound quality difference if I used either of the following:
1. Onboard sound connected to a digital to optical converter to a DSP
2. USB soundcard connected optically to the DSP
3. USB soundcard connected to 6 channel line driver connected to amps
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 11-21-2005, 04:47 PM   #4
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
I would advise against the converter as most i've seen require a power adapter that is 9volts,
in my previous setup I had a Soundblaster MP3+ connected via optical to a AC300, it was an awesome setup. Very very clean sounding. The only downside to that setup is you will lose volume control from the computer, you have to control it via the AC300.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 11-21-2005, 05:24 PM   #5
fonseca's Avatar
fonseca is on a distinguished road
I'm using a converter. See this thread for more info. Once I fed it the voltage it wanted, it worked great, and I've had no problems using it these past weeks.
Since you have an M10k, I think the converter is the best choice, unless you find a DSP that will work with the M10k's coax out. Your USB soundcard is hogging at least 20% of your processor, probably more. And there's little difference in sound outputting through the M10k's coax out instead of the USB card's optical out. I compared extensively with a PCI Audigy and could discern little difference, both in my car and connected to my respectable home theatre setup.
Running a six channel line driver to the amps would be a noticeable downgrade from the first two options. The only reason I would do that was if I already had an expensive analog EQ I wanted to use, and many models will boost the signal themselves, so line drivers probably wouldn't be needed.
You will still have volume control on your pc with digital out, however only the wave slider will function. At least with VIA's sound chipset. I have my master slider mapped to wave in Road Runner, so I can still control volume if need be. Although I usually leave it on 50%.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
fonseca is offline   Reply With Quote
Old 11-21-2005, 05:25 PM   #6
3onDubs's Avatar
Hmm...I just got my Ibus working so that I can use my steering wheel controls for everything...there is no way for roadrunner to control the volume?
EDIT: Sorry, just read this...that makes a huge difference
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 12-11-2005, 09:31 PM   #7
canopy's Avatar
canopy is on a distinguished road
Hi all,
I wonder if you could help me in this...
I have my audio system conected via spdif from an epia sp to the panasonic cy ac300 dsp, which goes to a Pyramid amp... the thing is that I'm getting ALOT of noise... from the weeeeeening of the car's alternator, to the spinning of the hard drive... all its nicely grounded and very well connected.
I thought that with this DSP I would have no problem with noise as the audio source is SPDIF...
Can you help?
thanks!
canopy is offline   Reply With Quote
Old 12-12-2005, 01:19 PM   #8
3onDubs's Avatar
Quote: Originally Posted by canopy
Hi all,
Can you help?
thanks!
That's strange...that's the main reason I wanted to go the ditigal route in the first place, to eliminate noise...hmmm. You should try and isolate the problem by pinpointing possible sound inducing factors in your setup. I don't know how everything in your car is setup to help you list the factors. How long are your RCA runs between your DSP and your amp? Are you using a crossover that is close to another power wire? Does your DSP share the same ground with your amp and PC?
Also, are you using a converter to go from coaxial to optical?
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 12-12-2005, 03:10 PM   #9
canopy's Avatar
Hi,
sorry I didn't say much about my setup...
So yes, I have a coaxial to optical converter between the mobo and the dsp and the RCA cables are no longer than 1/2 meter. All are connected to the same grounding point (which, I think, helps reducing the ground loop issue...). And I have no crossovers near the power lines...
I'm starting to think that there is something wrong with de DSP, as I bought it used from ebay....
Thanks!
Old 12-12-2005, 04:24 PM   #10
3onDubs's Avatar
Hi,
Thanks!
That seems like its an ideal setup...did you have an analog setup before this setup? If so, was there noise there? You could try and use a soundcard (without the DSP) to experiment on wether or not the DSP is really the culprit or not...I dont think it would be, but if the noise still exists when you go directly from a soundcard, then the noise is probably being introduced at the amp level...
...another thing that you could do is use an external soundcard's optical out to go directly into the DSP and see if that solves it...
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 12-12-2005, 05:16 PM   #11
canopy's Avatar
I can't see what's the difference between the optical out of the converter with the one of the external soundcard... As it is a pure modulated digital signal! Anyway, I don't have the possibility to test that.
I went directly to the DSP solution without testing the sound on my car with the analog from the mobo...althought it should have been the first thing to do
Old 12-12-2005, 05:21 PM   #12
canopy's Avatar
...aren't the amp's input audio grounds "fisically" separated from the power one?
BTW... I would almost bet that if I use the analog out from the mobo the noise will be probably the same issue...
Clarion DSP -- Optical inputs justav6 General Hardware Discussion 7 01-03-2008 01:51 PM
Car 5.1 Dsp Options Vs Pc 5.1 Dsp port20 Car Audio 13 05-29-2006 03:10 AM
Here's an easy one (DSP question) ummagawd Road Runner 9 12-06-2005 08:24 AM
Panasonic and MaPower users? RedGTiVR6 General Hardware Discussion 5 02-11-2005 04:33 PM
FS Panasonic ac300 Hu-less AC3 processor. dingofarmer Classified Archive 0 01-07-2005 09:10 PM
