This is my first install and I was wondering if someone might be kind enough to check over my headunit wiring. I have a 2005 Chevrolet Impala and in order to replace the stock headunit you need this interface:
http://www.cardomain.com/item/PERGMCO
I will be installing an Alpine CDA-9830 headunit and am trying to mate the two together. I have connected red to red, yellow to yellow, and black to black. On the GMCO side, I am left with four RCA ends which I have taped off(for speakers), two orange leads and a blue lead. Do I not need these?
On the Alpine end, I have taped off all the speaker leads due to the fact that I am running new speaker wiring directly to the speakers from the amps, a blue power antenna lead, and a pink/black lead which the manual refers to as "AUDIO INTERRUPT>TO VEHICLE PHONE"
The part I wanted to make sure about was the blue/white remote lead from the Alpine harness is the one I need to run for the remote turn on. If I have two amps, do I run the one wire to the first amp and then splice the wire for the second amp?
Please comment if my wiring scheme above is appropriate. Should I tape off the 2 orange and 1 blue wires on the GMCO? Thanks!
