Old 12-05-2005, 11:00 PM   #1
chitown_16's Avatar
chitown_16 is on a distinguished road
Do I Need To Beef Up My Alternator Or Anything Else
this is the stereo system i have
head unit: alpine cda9851
subwoofer: alpine swx type x 12 inch 1000w rms 3000w peak
amplifier: jl audio 500/1
do you think i need to do anything like add a capacitor or beef up my alternator i already got an optima batte
chitown_16 is offline   Reply With Quote
Old 12-05-2005, 11:15 PM   #2
viper24's Avatar
viper24 is on a distinguished road
in a grand am, i would say a capicator would be a good idea. if it was like a large truck or suv then no. just make sure to run 2AWG to that puppy.
2005 Dodge Ram HEMI
http://www.cardomain.com/ride/2239451
15" LCD touchscreen
Mac Mini
6" Headrest monitors
Modded Xbox
5 PSone screens going in doors
And another 15" LCD!
viper24 is offline   Reply With Quote
Old 12-05-2005, 11:30 PM   #3
cupcakes is on a distinguished road
Well, have you installed it all yet? If you're not getting heavy dimming when the sub is hitting hard, then there is no need to do anything.
High output alternators are generally for systems drawing 1500+ watts. Caps are completely useless, don't buy them.
I have 2 Memphis HPO 12s running on a Memphis PR1000.1 amp in a 96 4 cyl Camry, and I don't have enough dimming to warrant any power upgrades. That's with double the wattage you are running.
If you ARE experiencing heavy dimming, Google "big 3". That's an almost free upgrade to your power system that is easy and far more cost effective than an alternator.
~Cupcakes
cupcakes is offline   Reply With Quote
Old 12-05-2005, 11:34 PM   #4
Unregistered User
ODYSSEY's Avatar
ODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant future
"big 3" did nothing.
ODYSSEY
Quote: Originally Posted by Tidder View Post
Digital-Car UK|
(\__/)
(")_(")
ODYSSEY is offline   Reply With Quote
Old 12-05-2005, 11:39 PM   #5
chitown_16's Avatar
Im Running 4 Guage Becuase Thats The Largest I Can Run Will I Be Okay
Old 12-06-2005, 12:21 AM   #6
That was descriptive. Do you mean to say ''big 3'' turned up no results or the big 3 didn't help your power situation?
If it didn't turn up any results, do the obvious thing and add a keyword or two such as ''car audio''.
As for wire, yes 4 guage is fine. You actually didn't NEED to go even that large for your amp, but either way is good.
~Cupcakes
Old 12-06-2005, 12:48 AM   #7
chitown_16's Avatar
what do you mean i ddint have to go that large for an amp
i think i should have went with the jl audio 1000/1
I HAVE A ALPINE TYPE X 12 INCH SUBWOOFER
1000 WATTS RMS
3000 WATTS PEAK
Old 12-06-2005, 12:49 AM   #8
I meant that large of a power cable from your battery to your amp. But yes, most definitely the 1000.1 would be better for your particular sub, but I wouldn't pay JL's prices for 1000 watts.
~Cupcakes
Old 12-06-2005, 12:54 AM   #9
Unregistered User
ODYSSEY's Avatar
More direct help for "big 3":
http://forums.carreview.com/showthread.php?t=678
Quote:
As many of you know, upgrading the "Big 3" wires in your engine compartment can lower the overall resistance of your entire electrical system. The effects of the lower resistance are typically:
1) Reduced dimming and smaller voltage drops
2) More stable voltage and better current flow
3) Less strain on your vehicle's charging system
So for those of you looking for a cheap and easy way to upgrade your system and help out your electrical system without adding a high output alternator or an aftermarket battery, this is the modification for you. If you have heavy dimming or are getting large voltage drops during loud bass hits, but you don't have the money to spend on a high output alternator or a battery, upgrading your vehicle's "Big 3" will usually help to reduce and sometimes even eliminate the problems. So without further ado, the "Big 3" wires are:
1) Battery negative to chassis
2) Alternator to battery positive
3) Chassis to engine
Now, I suppose it would help if I explained what each of these wires does, and to do that I would like to paraphrase an explanation by IMTfox from a while ago: Think of your vehicle's charging system as two different circuits, one consisting of your amplifier and your battery, and the other consisting of your alternator and your battery. The current in your electrical system flows from your positive battery terminal to your amp, from your amp's ground to the chassis, and then from the chassis back to the negative battery terminal. But how does it get to the positive terminal in the first place? That's where the alternator comes in. Current in the second circuit flows from your alternator's positive post to the battery's positive terminal, then from the battery's negative terminal to the chassis, and from the chassis back to the block, which happens to be the grounding point for your alternator.
So, from your battery, you have the power wire going to the power terminal on your amplifier and then your amplifier is grounded to the chassis of the vehicle. From here the current needs a way to get back to the negative battery terminal, and that way is through the first of the "Big 3," the battery negative to chassis wire. Upgrading this wire will "upgrade" the circuit between your battery and your amp by giving the current a larger path to flow through to get back to the battery.
Now, think of your alternator as the battery and your battery as the amp. From the positive post on your alternator, you have the second of the "Big 3," the alternator to battery positive wire supplying "power" to your battery. From there the battery, just like your amp, is grounded to the chassis through the wire mentioned in the previous paragraph. Again, the current needs a way to get from the chassis back to the alternator's "negative terminal" and that way is through the last of the "Big 3," the chassis to engine wire. Since your alternator is most likely mounted to your engine block using a metal or conductive mounting bracket, you can simply add your new wire from the chassis to one of the mounting posts for the alternator. Upgrading these two wires will "upgrade" the circuit between your alternator and your battery, again giving the current a larger path to flow through.
Now that you understand exactly what the "Big 3" do, it's time to upgrade them to a larger gauge wire. You can use regular power wire from installing your car audio equipment, ring terminals, and crimping equipment just the same as you would for any other install. Let's start with the first of the "Big 3," the battery negative to chassis wire:
1) Disconnect your battery's negative terminal and get the stock wiring out of the way. You might have to cut it and crimp a new ring terminal onto it. I found it helpful to use aftermarket battery terminals with multiple ports on them also.
2) Scrape away the paint and drill the hole for your connection of the larger wire, or connect it to the stock grounding point. Either way you do it, make sure it is bare chassis metal, not covered by paint, and that the connection is as tight and secure as possible:
3) Secure the new wire to the chassis and reconnect the vehicle's stock chassis ground, but DON'T reconnect the vehicle's negative battery terminal yet! You may find it helpful to cover the negative battery terminal with a cloth or other non-conductive material and just lay the terminal on it until you're ready to reconnect it later.
Moving on to the next of the "Big 3," let's upgrade the alternator to battery positive wire:
4) Locate the vehicle's alternator and look for a terminal post connected to it. The post shouldn't be hard to find. It should have only one wire connected to it, and it should lead to the positive terminal on the battery, possibly through the fuse box.
5) Disconnect the stock alternator to battery positive wire from the positive post and connect it to the post again with the new wire added.
6) Run the wire either through your fuse box if applicable or through a fuse. The fuse should be sized to match the max ampacity of your wire, not the output capability of your alternator. As you can see I just went through the fuse box, so my upgrade is probably not making as much of a difference as it could if it were fused externally, but my alternator is capable of withstanding the draws anyway so I'm not particularly worried about it. If I ever begin to see a problem w/ current draws, I will probably fuse the wire externally with a 300A or so fuse...
7) From the fuse, connect the wire to the positive terminal on your battery, again, leaving the stock wiring connected when you're done. The picture below shows the alternator to battery positive wire run from the alternator through my fuse box to the positive battery terminal.
Last, let's move to the chassis to engine wire: (Again, because your alternator is grounded to the block, all you need to do is find a bolt somewhere on the block and connect it to the chassis. The alternator's mounting bracket is usually a good place to find these bolts).
8) Again, either drill a new hole or connect this wire to the stock chassis ground. From the chassis ground, run the wire back to one of the mounting posts for the alternator (or to a bolt on the engine block).
9) That's it! You're done. Reconnect the vehicle's negative battery terminal and check out the difference! Below is a shot of the "Big 3" upgraded in my car. The other wire you see coming out of the battery's positive terminal is obviously my amp's power wire.
Helpful hints:
1) Leave the stock wiring attached after you're done. Don't replace the stock wiring, add onto it. Current will take the path of least resistance anyway, so replacing the stock wire will only make more work for yourself.
2) When fusing your alternator to battery positive wire, fuse it toward the battery end of the wire. As IMTfox points out later in this thread, the battery will explode if it's overloaded, while the alternator will only burn out its regulator which won't cause much damage except to the alternator itself. Exploding batteries are no fun!
3) When crimping large gauge terminals for 1/0awg and sometimes even 4awg, a vice works well. Crimp one side of the terminal at a time, creating an overlapping edge. Put the boot around this and then wrap it in electrical tape if you want. the most secure connections will occur in this way.
4) Lastly, prepare all your materials and tools BEFORE you are ready to upgrade. Know what you are doing before you start so you can be done as quick as possible. The majority of vehicles have computers that will reset after the battery is disconnected for a long time and they can cause older vehicles to do strange things if they reset.
Hopefully this clears up most of the questions you had about why we upgrade the "Big 3" and how it helps to stop dimming and other electrical problems.
ODYSSEY
Digital-Car UK|
(\__/)
(")_(")
Old 12-08-2005, 12:21 PM   #10
recompiler's Avatar
recompiler is on a distinguished road
Cupcake, why would you say a capacitor is useles? Is there an explanation? I added a cap on my old civic because the lights weren't as bringht as I remmember them being before I put in the amp and subs. Now considering how much of the gear to pull from the civic into the new eclipse.
2004 Eclipse GTS v6 Turbo, NOS
Plantronic in-dash LCD
Via Epia M2 1200 with WiFi and CF Microdrives
OBD2
Rino 120 GPS
recompiler is offline   Reply With Quote
Old 12-08-2005, 01:03 PM   #11
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
~Cupcakes
funny thing is, some people actually believe everything they read....... well read this: THIS IS NOT TRUE!!!!
from an earlier post in this thread:
Quote: Originally Posted by turbocad6
A properly used stiffening cap is to your electrical system, what your shock absorbers are to your suspension. You could drive your car without shock absorbers but the constant pounding will ruin structural components & transfer the shock to the rest of the vehicle. the stiffening cap will actually prolong the life of your alternator in the same way, by "absorbing" the big instantanious demands for high current & smoothing them out to a certain point. just because your caddy has shocks, doesn't mean you can go baja it off road, obviously a stiffening cap isn't going to cure all & if the overall average draw of the system & the rest of the vehicle is higher than the output of the alternator the cap will not solve your problem. you can't expect a stiffing cap to supliment a true 1000+ watt system, & even a bunch of batteries will only prolong the inevitable of draining your reserves, to run a system that has big power demands you must increase the output of the alternator to meet these demands.
the best solution is a combination of an aux battery close to the amps & a stiffening cap. A configuration like this will allow you to draw up to & even over your alternators output for short periods of time without a problem....
as far as idle drain,depending on the cap design, it can draw anything from a real small amount of current(.01-.02ma) up to enough to kill your battery in a several days. the best way to install a cap(s) is with a high current relay that disengages it from the battery while idle(parked). most carbon based caps are installed that way manditorily, as they will draw up to & over .06ma wich is enough to kill a battery overnight ...
turbocad6 is offline   Reply With Quote
Old 12-08-2005, 02:04 PM   #12
binary.h4x's Avatar
binary.h4x
Turbocad, that thread is hillarious.
binary.h4x is offline   Reply With Quote
Old 12-08-2005, 02:45 PM   #13
turbocad6's Avatar
..yeah man, A little knowledge is a dangerous thing
Old 12-08-2005, 10:51 PM   #14
http://www.toyotanation.com/forum/t88047.html
Too long to quote.
~Cupcakes
Old 12-08-2005, 11:40 PM   #15
turbocad6's Avatar
a quote of a quote..... from a toyota forum..... see, that's what I mean, you read it so it must be true.... believe what you want..... I believe what I said & I've done more than my share of big systems ... not read about them......
have you ever heard of the term "bench racing", well were doing the vertual equivalent of that with car audio right here....but in the end it's real world results that count
a cap will not hold an extra output for an extended period of time.... it is very possible to have a bass drone outlive the usefullness of its current charge, but that's not the point..... a car can still bottom out with shock absorbers, does that mean you'd rather not have them?
are caps over rated & miss-used? definately, but they are far from useless...
Aiwa + Pioneer Beef Rockarolla306 Car Audio 7 11-20-2007 08:39 PM
