Old 12-30-2005, 08:10 PM   #1
DOTC is on a distinguished road
2000 Jetta single din to double din question
Alright, as it says in the title I have a single din cassette stereo. I bought a double din factory stereo that came out of a 03 Jetta. Question is the connectors are different on the back of the stereo? I thought maybe it was because it was an 03, but I saw another double that came from a 2000 model and it was the same. Is there anyway to convert the connectors to fit at all?
Ive searched through the forum and cant find anything I hope someone knows what I'm talking about. Thanks
DOTC is offline   Reply With Quote
Old 01-01-2006, 08:43 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
sometimes metra electronics makes reverse harnesses...for when someone has cut off the harness and you need to get a harness back in the car....now if they make one for your specific car or not is a different story - you'll have to check that one out!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
FS: Single DIN case and slotload DVDROM for Via Epia MIIK tf82 Classified Archive 0 06-10-2005 02:16 AM
FS: Indash Double Din 6.5" LCD DVD/AM/FM CDesigns Classified Archive 2 05-12-2005 03:18 PM
double din case with mounting points for the liliput and the xenarc rotarypower101 LCD/Display 5 03-31-2005 03:07 PM
Can double din hold pull out and radio? jnusaira Fabrication 12 06-08-2004 04:32 PM
Question about BIG 8-pin DIN koyoutou Newbie 3 10-02-2003 04:56 AM
