01-19-2006, 08:58 AM
#1
VIA MII 1000 5.1 Sub out
Is there a trick to getting the sub out to work on the built in sound on the VIA MII 1k motherboards? I have 5.1 enable in the volume control screen, and have my MTX amp hooked up to the sub out(mic in) on the board. I have a regular head phone type plug to RCA plug Y cable thingy. Currently I have the same cable going from the regular front speaker out to the big MTX amp, which is daisy chained the little MTX for Left channel mids/highs, which is daisy chained to the other little MTX for right channel mids/highs. This setup is the same setup I had with my old blaupunkt head unit, and it works, but I'd like to be able to indepently change the sub volume.
In theory this should work, but I get nothing. I have never dealth with sound card 5.1 solutions as I have an oldschool Denon decoder/amp at home. Is there something funky I have to do with wiring as the output is also used for the center channel. I've also downloaded the newest drivers from the Via website with no luck.
So, is there a trick or do I have a dud motherboard?
Thanks,
ZtH01
01-19-2006, 08:01 PM
#2
wait, did you say that your sub out was your mic in? It should be the ceter channel. What you may want to do is get an active crossover that can split the sgnal before hitting the amps, that way you get your center highhs and your sub lows without sacrificing anything.
. sub/center out ~~~~~~~~~~~~~to center amp
(MII)---------------------(crossover)========
.~~~~~~~~~~~~~~~~~~~~~~~to sub amp
You have your big amp to your two small amps? why? I'm not undestanding the reason or thought process behind it. I'm a bit slow theses days, so forgive me.
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
01-19-2006, 08:30 PM
#3
On the Via boards the mic input can be switched to sub/center out by enabling the smart 5.1 function.
I have no center speaker... I just want to have a dedicated channel to the sub amp, so I can control the bass level a little better.
My MTX amps have line outs with an adjustable crossover. So, the sub amp gets the the full range input from the VIA board. It powers the subs, and sends a high pass line level signal to the first smaller MTX. That amp powers the left set of component speakers. It sends a full range(which is effectively high pass, because of sub amps output crossover) low level signal to the other little MTX which powers the right set of components. It works fine, and no additional crossovers are needed.
So, it's not a problem with the amplifiers, for some reason the the smart 5.1 thingy is not working. I tried hooking the sub amp up to the rear channel of the sound card too, which in non 5.1 mode is the line in. I got nothing as well. So, I have a feeling the smart 5.1 was never really enabled and I just need to figure out how to enable it.
Thanks,
ZtH01
01-19-2006, 09:13 PM
#4
i see it now. that's diffeent, didnt know you could do that. With your problem though, if its VIA software, i'm sorry, i can't help you.
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
01-20-2006, 08:30 AM
#5
sounds like one of those stupid settings,.... I had the same sorts of problems when I got my first surround sound card.
Make sure it is set for surround sound through the contorl panel, in windows. This ended up being my problem more times then not.
Progress,.... that is what I keep forgetting ;)
planning_[++++++++++]. 110%
parts___[++++++----] around 60%
install___[-----------] -9,000%
01-24-2006, 01:53 PM
#6
I was having a go at this the other night, and didn't manage to find a solution, so would be very interested to hear one!
01-24-2006, 01:56 PM
#7
cheap custom title
Don't know if it's only a software solution or maybe also jumpers that need to be set...
Or maybe driver versions? Did you try the vinyl drivers?
01-24-2006, 02:03 PM
#8
I've not tried any drivers other than the latest via ones. There is one jumper on the board which selects what the RCA type socket outputs (either Composite video or 5.1 surround) I tried both positions on the board and it made no difference to what I was trying to do.
The other thing I did think of was that maybe you needed to be playing a surround sound sound source (5.1 DVD) for the other chanels to have any effect? I only tried mp3s.
01-24-2006, 02:42 PM
#9
cheap custom title
Are you sure they are the latest?
Via is known for not putting them in the right place on their website... Check Viarena...
01-24-2006, 07:00 PM
#10
I'm not completely sure if I've got this figured out, but I'll give it a shot.
You've got three min-jacks, one is Front left/right, one is rear left/right, other is sub/centre.
First, you have to make sure that your Y-splitter is stereo, and not mono. Second, you have to make sure that you're connecting the sub output to the amp, and not the centre channel output. It's just like a left/right stereo connector, except instead of a right and left channel, you've got a sub and a centre channel.
If it's not working, try connecting the other half of the Y to the amp instead.
Also, try using a DVD with 5.1 as your reference.
Cheers,
Kris
How Much Horsepower Can I have And Still Go To Heaven?
03-11-2006, 08:46 PM
#11
I have another question which kinda fits here. When all the 3 jacks are used for the speakers, what do I use for mic and line-in??
According to via, there is a "Front-panel audio connector (Mic-in and Line-out)" on the board, however, it didn't come with an audio front panel and I can't find that thing on the net.
Asus MicroATX with GeFore 6100, Mobile Sempron 3300+, 1Gig Ram, 320GB 3.5" 7200UPM HDD, M2-ATX, Gain/Xenarc 7"
Fast IS my copilot
03-12-2006, 03:32 PM
#12
I also wanted to know if anyone has used the CDAUDIO input as an AUX/LINE IN for the via boards, because I have the MII10000 and it has 3 mini jacks on the back, and when in 5.1, you have no input aside from the MIC in, which is mono, and would eliminate the ability to add on a MIC. I havent got the OS on my CarPC yet, but I have already made an adapter to go from RCA to the CD audio input.
I was curios if anyone else had done this before, I personally haven't used an analog audio cable on a CD-ROM since I was installing ISA sound cards. I was going to use this input for my XM input. Any advice would be appreciated.
John~
03-13-2006, 08:02 PM
#13
bump (??)
Fast IS my copilot
03-17-2006, 12:34 AM
#14
John~
You don't even have a mic input then if I am correct.
How did you make the adapter? Which cable on the cd spdif input goes where?
I have posted my question on the via arena board, hopefully we'll get some advice there (which I honestly doubt).
Fast IS my copilot
03-17-2006, 01:32 AM
#15
actually the MII10k has a 10 pin F_AUDIO connector, to use the mic input when the board is using the 3 audio connectors on the back for 6 channel out, you just remove the two red jumpers, and connect a mic header to the board, you can also use the line out function the same way.
and the way that I have made my aux in connector for my board, is I took an analog audio cable for a cd rom with the same connector as the one on the board, and cut it, used a multimeter and my mainboard manual to find out which wire is which, and then soldered on a 1/8" stereo in-line connection. I haven't gotten a chance to do anything with my system, as far as testing goes I am still playing with operating system setup, and I don have my permanent hard drive yet (should be here on saturday or sunday at the latest0 but I plan on checking out if it works because it is such a simple way to add an aux input, and it would allow me to have my XM and my 5.1.
So Far: MII10k Mobo, 1GB Corsair PC3200, 100GB Hitachi HD,M2-ATX PS, Ampie Case, XMD1000, Panasonic CD-RW DVD-ROM. Orinoco Gold, Lilliput 629, WiFi, TV/FM, Amateur Radio, and XM Antennas
NEED TO BUY: GPS.
NEED TO INSTALL...EVERYTHING
| Thread Tools |
| Display Modes |
Linear Mode
