Old 02-03-2006, 07:21 AM   #1
dbzeag is on a distinguished road
Wiring ignition line
So I was thinking about this last night because this project has totally emcompassed my conscious and unconscious thought patterns continuously, I have 2 devices that need to use the ignition wire to determine when to start.
I have an amp in the trunk that needs a delay to start after the ignition line goes high.
I also have an M2 that needs to start, but without the delay.
What type of wiring and/or relays and devices would I need to power such a situation?
What should I use to split the ignition line to drive those two devices?
Thanks for your help!
dbzeag is offline   Reply With Quote
Old 02-03-2006, 07:12 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
M2-atx?
or what m2 are you talking about?
if you're not talking about the m2 power supply, you should look into getting either it or a power supply that has the amp turnon delay built in (which the M2 does)
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 02-03-2006, 08:22 PM   #3
Quote: Originally Posted by Red GTi VR6
M2-atx?
I am talking about the M2-ATX power supply
Old 02-03-2006, 09:18 PM   #4
_
ok - so then...it's already got an amp turn on delay built into it...IIRC
the M2 will turn on the computer only after it sees a regulated voltage coming in...
then it waits a but before it sends the turnon to the amps...thus the anti-thump technology
it's the same withthe M1-ATX in my car
no delay circuit wired into the car...it works like a charm
Jan Bennett
Old 02-04-2006, 09:26 AM   #5
Wow, I am an idiot and just read the directions. That makes a lot of sense :-P
Thanks!
Old 02-04-2006, 09:49 AM   #6
_
np! it happens to the best of us!
good luck with it all!
Jan Bennett
wiring 528T timer McGinty Power Supplies 16 02-01-2006 02:32 PM
SP13000 - Line Input - Sirius Radio thestoogeo General Hardware Discussion 2 01-13-2006 12:23 AM
Line Driver Vs. Amp Sensitivity Adjustment 3onDubs Car Audio 5 11-28-2005 08:37 PM
Wiring Xenarc to wiring harness? deftones8769 Power Supplies 5 04-10-2005 10:07 AM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
