Old 02-06-2006, 05:31 PM   #1
LiquidKernel's Avatar
LiquidKernel is on a distinguished road
Running Amp During Crank?
Since the M1-ATX runs during crank, it still powers the Remote Amp On line, so the amp is running during the entire process (in theory playing music since the carpc might already be on). I'm thinking it's best to killt he Remote Amp On line during crank. Should I just setup a SPDT relay between the REmote Amp On line through the normally connected pin, and during crank pull the relay to temporarily turn off the amp? That seems like a very simple elegant solution. Of course this can be done through a solid-state setup using an optocoupler and P-channel MOSFET.
95 Volvo 850 T5 • Konis • ECU @ 17psi • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • TSX HID Projector Retrofit • Hella Raintronic
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 02-06-2006, 06:11 PM   #2
3onDubs's Avatar
3onDubs is on a distinguished road
I think that most (if not all) car amplifers are designed for specific use in a car environment.....
....like, I think they are designed for variable input levels as to ensure engine crank survival
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 02-07-2006, 03:21 AM   #3
Well, my worry is not whether or not it will survive crank, but rather that it will add extra drain during crank. On top of that, I'd rather have the music shut off during crank for a second.
Old 02-07-2006, 08:48 AM   #4
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
it shouldn't cause a problem
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
Help hooking up subs and amp? Need advice... jedi7001 Car Audio 6 05-17-2005 02:28 AM
Car Audio People, Help me pick an amp / Jeep GC w/ Infinety System hevnsnt Car Audio 3 12-07-2004 07:34 PM
Amp setup. Heat concern. d_sellers1 Car Audio 2 07-09-2004 10:58 AM
Having problems running audio from my Shuttle to my amp 0din General Hardware Discussion 3 06-19-2003 02:41 AM
