haha, okay
High imputs, known as speaker elevel inputs, are using the speaker wire from the head unit. Low level is RCA, which uses the preamp RCA outputs from yoru headunit. You want to use RCA wiht your carputer though. definitely. What you do is you take a 1/8 stereo (3.5mm) to RCA adapter ($6 at Radio Shack) and go straight from your mac mini to the amp (easy way) or use an eq (hard way and obviously not the way you're going to do it).
And they're not pointless if you're using your stock HU and upgrading your amp, a HU without preamp outputs, or you're using multiple amps from your HU (one for speaker, one for subs). They're practical depending on your use. It gives you options.
Speaker-level input
Number and type of speaker-level inputs. Speaker inputs let you connect an amp to a receiver that lacks RCA preamp outputs.
from
http://www.crutchfieldadvisor.com/IS..._glossary.html
For a carputer though, they're pointless
And any idiot can install an amp IMO. Wring the mac mini in your car is harder than wiring a car stereo. The hardest part was finding a way through the engine firewall to get to the battery. If you are afriad or need guidance, make firends with a guy who does stereos and he'll walk you through it.
