Old 02-08-2006, 03:15 PM   #1
cartdan is on a distinguished road
USB Sound Solution - newbie question...
I've searched these forums, but can't find a lot of info on what people are using for a USB sound card solution. I'm putting together a carpc that will run without a head unit, and wanted something other than the onboard sound off of the motherboard. I've looked at the Griffin Imic, GWC AA1500 and the Soundblaster variants, but don't know much about the sound quality that comes out of any of them. Any advice is greatly appreciated...
cartdan is offline   Reply With Quote
Old 02-08-2006, 03:45 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
The soundblaster units generally produce better sound quality. However USB sound devices pass off processing to the CPU, rather than having on-board processing. That's something to consider, especially if your'e going with a lower-power motherboard like an EPIA variant.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-08-2006, 05:21 PM   #3
Genesisfactor is on a distinguished road
not doubting your searching, but i'm surprised you didn't see anything. Check the for sale threads sometimes when in doubt on equipment. If you see a repeat name, like griffin powermate, its a popular product.
As DP said, Creative's SB cards, both USB and PCMICA, are considered to be the best of the bunch. Audigy 2 NX is a popular USB card. I use solely usb audio cards right now(i like the ability to quickly switch between 5.1 surround sound and headphones and since the jack is right there to the steeo, my PPC has a hi fi go too ). Overall, hey perform wonderfully and i wouldn't hestiate getting one of them for the hell of it- esp since the NX comes with a remote control!
You can alter the bandwith used in your settings. Also, it only takes up 10%, via processor, trasnmeta, below 300mhz pentium, i'd worry, anythign else shoudl be fine
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 02-12-2006, 08:20 PM   #4
volum3rider is on a distinguished road
Hows coming out of hibernation working for the usb sound card? Does it start right away like a regular sound card or is there a little lag with all usb devices?
volum3rider is offline   Reply With Quote
Old 02-13-2006, 12:38 PM   #5
Admin
gnomad is on a distinguished road
I was using the Audigy 2 NX for a while, but eventually gave up on it. The problem with the NX is that it doesn't have 44.1 khz D/As, so everything needs to be resampled to 48 khz, in software, by your main CPU. Furthermore, the SB drivers that handle it do a rather poor job. If you are only using two chanels of audio output, you are better off with the $30 Turtle Beach Advantage Micro.
-g.
gnomad is offline   Reply With Quote
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Guys with External USB sound.......... camsgs3 General Hardware Discussion 8 12-03-2004 11:57 AM
Sound Quality with External USB Soundcard nirvanades General Hardware Discussion 3 08-12-2004 06:34 PM
Cable extensions question (IDE to USB, longs, place...) windalo Newbie 2 08-09-2004 09:36 PM
3m usb touchscreen controler question? kalito Input Devices 6 02-23-2004 07:45 AM
