Old 02-09-2006, 05:37 AM   #1
seninha's Avatar
seninha is on a distinguished road
How to connect AMP to 4 channelsoundcard
As the building part of my project is finish, I am now working on the software.
I bought a 4 channels soundcard, because I want t be able to get all the sound to the back when my son is watching his movies.
Now I wanted to test the sound and pluged my headphone to the front output and I get sound.Problem is that if i plug the headphoen to the rearoutput no sound is comming out :?
For this idea I bought 2 jacks.-->RCA cables
Both cables have to go apart from eachother into the amp.
Is this suppose to work or is my soundcard not working good.
All drivers are installed and in the set up i put it on four speakers.
This is the Sweex 4 channel soundcard:
I use Media player to trie it out. Is this player able to get the sound to four speakers or do I need a different player :?
Gods right foot!!
Mercedes ML320. Intel D945GCLF2,1024mb DDRII,160Gb S-ATA HD,HDradio,7"Touchscreen,2x 7"build in headrest screens,OBDII reader,Centrafuse.
seninha is offline   Reply With Quote
Old 02-09-2006, 07:22 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Int he Windows Control panel, there's a setting to choose what type of speaker setup you're using. Is that setup to use four speakers?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-09-2006, 10:03 AM   #3
seninha's Avatar
Yes. I have already choose the right amount of speakers.
I also tried 5.1 and 7.1. But non of those make th back out put to work.
Gods right foot!!
Old 02-09-2006, 10:08 AM   #4
bad-at-this is on a distinguished road
I know for my sound to mix to the rears I have to use the drivers from the vender and enable an option to mix front to rears when no actaully rear channel exists. You may want to look into that. Also I am having a problem with my front mixing 2 the rear for SOME audio sources. Try something different like a dvd and see if you have sound then.
-Bad
bad-at-this is offline   Reply With Quote
Old 02-09-2006, 10:22 AM   #5
Jahntassa's Avatar
Jahntassa is on a distinguished road
Yeah, unless you have specific software that came with the card to 'create' audio for the rear channels, you won't hear anything. It's possible that you'll hear DVDs if you have a player that supports multichannel, like some versions of PowerDVD
Jahntassa is offline   Reply With Quote
Old 02-09-2006, 10:49 AM   #6
seninha's Avatar
Problem is that I dont have a DVD player to attach , so I can't test that.
I'm gonna see if the possibility is there in the drivers to mix the front to the rear
Gods right foot!!
FAQ: Connecting your soundcard to a Volkswagen Monsoon Amp kbyrd The FAQ Emporium 88 09-04-2009 12:32 AM
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
AMP wont turn ON!! HEELP! pdjafari Car Audio 1 10-15-2005 08:43 PM
Problem Connecting both CarPC & H/U Audio in Amp!!! togaf Car Audio 4 05-17-2005 05:17 AM
Having problem with AMP, need HELP!! ryuandwings Car Audio 31 05-01-2004 08:31 PM
