Old 02-12-2006, 08:33 AM   #1
Biograph1001 is on a distinguished road
Brand new AMP, Busted..
Hi! This week i bought an Infinity 5760A Amp, 6chan amp.... i installed it, replaced my old amp... it sounded nice at first when the car was not running, this aint a groundloop problem so continue reading please :P... any who, when the car is running i get this awfull hiss only from the front right channel, when the car isnt revving at first the hiss aint noticable, but when i rev the engine a bit the hiss builds up and then stops building up to become static... so i dont know, i have tried 3 groundpoints and tried switching around my speakerwires and all... oh, and i did this test without any input to the amp, had nothing connected to the low level inputs.. My first impression is that the amp is somehow broken, some transistor or something at the front right channel is busted? Keep in mind that the amp was like 3 days old..
Please help!
From the land where all the blond hot babes come from. Everyone is named olga and the weird thing is that we all talk with a swizz accent... give it your best guess.
Biograph1001 is offline   Reply With Quote
Old 02-14-2006, 04:40 AM   #2
Greeney is on a distinguished road
open ur amp case and look for any noticible damage. sounds like you dont have a good enough ground to me, scrape away as much paint till u reach bare metal
Video of My Sub- (playing Mike Jones- Guess Whos Back)
RE SX12 at 35hz
Resonant Engineering 12
Greeney is offline   Reply With Quote
Old 02-14-2006, 05:03 AM   #3
maded is on a distinguished road
just hijacking your post, BioGraph...
i don't really like the idea of scrapping paint off the body for a ground... getting ground from the batt works just as well, wouldn't it?
maded is offline   Reply With Quote
Old 02-14-2006, 08:43 AM   #4
Will Albers is on a distinguished road
sure, just make sure you ground cable is the same gauge as your 12v cable.
pretty pricey where it would be easier just to scrape away the paint, put in a self tapper and then spray some rustoleum over the bare metal. To each their own
Will Albers is offline   Reply With Quote
Old 02-19-2006, 05:37 AM   #5
tech55 is on a distinguished road
you need the best ground you can get with the shortest length of wire. The shorter the wire the less resistance and less chance for any ignition noise to enter the amp or anything else hooked to it. I would say hook it to the body. Running a long wire to the battery is like an antenna for EMI into the grounding of all your equipment
tech55 is offline   Reply With Quote
Old 02-19-2006, 10:20 AM   #6
gameboy's Avatar
gameboy is on a distinguished road
pull the speaker out and make sure the wires attached to the speaker are good and tight, also you may want to upgrade the ga of the speaker wire u are using.
also, check to make sure your are running your speaker in the correct polarity.
one last comment - make sure your speaker wire is not grounding anywhere
95 Mazda Protege LX
Worklog
Overall [Project Dead] 0%
2003 Nissan Altima
[XXXXXXXX--] 80% Planning
[XX--------] 20% FABRICATION/INSTALLATION
Worklog
gameboy is offline   Reply With Quote
Old 02-19-2006, 11:49 AM   #7
DavC is on a distinguished road
swap over the front left and front right speaker cable on your amp.
Does the problem stay in the same place or move to the front left?
DavC is offline   Reply With Quote
Old 02-19-2006, 11:54 AM   #8
Jahntassa's Avatar
Jahntassa is on a distinguished road
Yeah, try what DavC says. I had to swap my front left channel with my rear left channel going from my wife's Pioneer headunit to the Sony 4 channel amp she has, same kinda issue, and it just 'went away'. So try rearranging the RCA connections and see if you can make it go away, then reconnect the speakers to the amp so the RCAs and speakers match up.
Jahntassa is offline   Reply With Quote
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
Amp running hot...?? Emerica2843 General Hardware Discussion 5 02-08-2006 06:40 PM
Amp running hot...?? Emerica2843 Car Audio 6 01-29-2006 08:29 PM
vw mk4 monson amp and another amp colorless Car Audio 33 10-03-2005 01:32 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
