The MP3car.com Store
Thread Tools Display Modes
Old 02-18-2006, 07:18 PM   #1
My Photos: (0)
2ohm or 4ohm sub???
which is better and why?? thanks for ya'lls oppinion..
Risk_ldp is offline   Reply With Quote
Sponsored Links
Old 02-18-2006, 07:43 PM   #2
kirbycope's Avatar
Vehicle: 2007 Chevy Aveo Hatchback
My Photos: (0)
it doesnt matter, less ohms, the louder/more wattage they are. all subs can be wired in different configurations from 8 ohm to 1/2 ohm. It really depends on the wattage/ohm rating of your amp.
Post Whore's tip:
User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
kirbycope is offline   Reply With Quote
Old 02-18-2006, 07:53 PM   #3
My Photos: (0)
good to know, thanks... new to caraudio learning more daily...
Old 02-19-2006, 02:54 PM   #4
mbuchman's Avatar
My Photos: (0)
If you are new to car audio, then you may want to go here
http://www.bcae1.com/
-Matt
mbuchman is offline   Reply With Quote
Old 03-04-2006, 04:05 AM   #5
Farrow099's CarPC Specs
My Photos: (0)
kudos on that call - that site is a good read for anyone
Farrow099 is offline   Reply With Quote
Old 03-04-2006, 02:55 PM   #6
3onDubs's Avatar
Vehicle: 2004/BMW/325i
My Photos: (0)
It depends on the amplifier powering the subs and the number of subs that you have. If you have a mono amp that is one ohm stable....your going to watn to take advantage of that fact and configure your subs so that you can wire them down to 1 ohm. 2 dual 4 ohm subs, for example, can be wired together down to 1 ohm, while one 2 ohm sub can be wired down to one ohm. You should basically pick out the subs you want and then get the amp to match.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 03-05-2006, 08:33 PM   #7
My Photos: (0)
ive got a kenwood that says @ 1ohm is 900 watt... also copped the alpine type R supposed to only 500watt rms--- should i wire this @ 1 ohm???
Old 03-05-2006, 09:38 PM   #8
Vehicle: 89 Volvo 740 GL
My Photos: (0)
NO
if your kenowwood has 900W rms and the same as another guy's on the forum, you can make it 4 ohms at 550W, which is find for the subs.
Here's the thing. The impedance (ohms) depends on what you plan to do. If you get a hgih powered sub and want to run multiple subs, you can do it wiht either 2 2Ohms subs in parrallel (4ohms total) or 2 4 ohm subs in series (2 ohms). That's where impedance matters. Your amp, however, can push more power with less impedance, so you can choose subs based on that.
***same thing 3on said, but i hope it makes it a bit clearer. If you wnat, make a list of subs you want and the amp you have and i'll mix and match***
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 03-06-2006, 03:12 AM   #9
DavC's CarPC Specs
Vehicle: Vauxhall Vectra
My Photos: (0)
Surely 2x 4ohm subs in series would be an 8ohm load?
DavC is offline   Reply With Quote
Old 03-06-2006, 06:49 AM   #10
My Photos: (0)
damn it i reversed them! Thanks DavC. Do the OPPOSITE of what i said!
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Sponsored Links
Old 03-06-2006, 10:51 AM   #11
3onDubs's Avatar
My Photos: (0)
I don't know that much about ohmage (as i'm new to calculating them), but i think that if you have 2 4 ohm subs, than you can either run them together at 1 ohm or 4 ohm. If you have 2 2 ohm subs, than you can either run them together at 2 ohms or half an ohm.
You should look at the maximum power handling that your sub has. This number is usually much higher than the rms number. If they can handle up to 900 watts max, than you should be fine and you'll really be pushing that sub. If it's a 2 ohm sub, you can wire it to 1 ohm, but if it's a 4 ohm sub, than you can wire it to 2 ohms.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 03-06-2006, 01:31 PM   #12
Vehicle: 1996 Pontiac Grand Am SE
My Photos: (0)
The way to calculate impendance is like so. For series you just add them together, so if you had two 4 Ohms subs in series you would get 8 Ohms.
For parrallel you use the equation 1/Ohms + 1/Ohms until you run out of voice coils, then 1/Answer. For two 4 Ohms subs in parallel you would get 1/4 + 1/4 = .5 and then 1/.5 = 2 so you would have a final impendance of 2 Ohms.
You want to match the impedance to where your amp won't be pushing out too much wattage for your subs, more ohms is generally better for an SQ approach and less ohms is generally better from an SPL approach. I'm sure in your situation you will just want to match it to what your amp supports.
sssssss27 is offline   Reply With Quote
Old 03-06-2006, 10:04 PM   #13
Epon's Avatar
My Photos: (0)
So let me get this straight... I'm assuming I have the same Kenwood amp that is rated at 1ohm stable... my sub is dual voice coil @ 4 ohms... please tell me how I should wire this...
Epon is offline   Reply With Quote
Old 03-06-2006, 10:39 PM   #14
Snootch's Avatar
Vehicle: 2000 Pontiac Trans Am
My Photos: (0)
If your sub is dual voice coil, and each voice coil has an impedance of 4 ohms, you can wire both coils together in paralell like this:
This wiring will have the amplifier "see" a 2 ohm load. I assume you have the KAC-9152D amplifier? The amp will produce 900 watts RMS at a 2 ohm load like that.
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Old 03-07-2006, 08:15 AM   #15
DavC's CarPC Specs
My Photos: (0)
to get the most volume out of your speakers, you want to wire them in a way that their impedance is equal to the lowest stable ohm rating of the amp. If this is not achieveable, wire them in a way that they are the lowest rating ABOVE that of the amps lowest.
Sponsored Links
Trackbacks are Off
Right amp for sub? 92stealthRT Car Audio 15 01-30-2006 07:53 PM
Trying to setup a system and need recommendations Philly#1 Lex Car Audio 3 06-27-2005 10:39 AM
kicker 12" 4ohm sub 75.00 shipped tracker92 Classified Archive 9 08-30-2004 11:05 AM
Sponsored Links
Ad Management by RedTyger
