The MP3car.com Store
Thread Tools Display Modes
Old 02-20-2006, 12:20 PM   #1
AyrtonSennaD's Avatar
Vehicle: Summer car : 1995 Nissan 200 SX (SR20DET) Daily drive : 2002 Sentra GXE Touring
My Photos: (0)
Sound card : PCI vs USB help please
Ive been searching and reading the forum for more then 6hours try finding the best solution for the carpc project i want to start. It first i was thinking of using the external ubs sound card (Sound Blaster Audigy 2 NX) but i was thinking if a pci car would be better ? This is a critical because i don't want less sound qualiy that i already have in my car so if it could be at least equal at what i got it would be ok for me and i dont want to have to deal with the alternator noise in my speaker too. My current sound system setup is a alpine cda-7965 HU ,alpine 3321 eq and 2 MTX Amps for my componnent and my subs. For the car pc the parts i choose is :
VIA EPIA M10000 Mini-ITX Mainboard
Ampie Car Computer Case
radioShark for fm radio
80gigs samsung 2.5 hard drive
Lilliput 7' touchscreen
Any kind of help will be very much appreciated.
AyrtonSennaD is offline   Reply With Quote
Sponsored Links
Old 02-20-2006, 01:01 PM   #2
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
Hey bro,
I have the same thoughts. Sound is everything. I use both opticals on the Audigy NX SPDIF from NX to Eclipse Deck, the other Optical is for Sirius Radio and run 8v from my eclipse deck to the MTX amps so 0 noise and clear sound.
I chose the NX because I wanted the single PCI slot on the Epia board for a graphics card.
Sound is awsome, however the NX takes extra CPU power, and after almost a year of it running in the car I never touch the NX. So if you dont need that PCI slot I would go with a PCI sound card. Dont forget if you need a MIC and the computer is in the trunk this is another hurdle to over come.
Both ways you cant go wrong really, try and use optical as much as possible.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 02-20-2006, 01:08 PM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
The only significant difference betweent he PCI and the USB cards is that the USB will eat up more CPU than the PCI.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 02-20-2006, 01:53 PM   #4
My Photos: (0)
thanks guys
-zip-
Got a couple question. What case did you use i want the ampie case but i dont think i can add a pci card in it since the case is so small. And where did you get all your part. Am canadian too and i did not find one place near my home who sells those component.
thanks
Old 02-26-2006, 09:01 PM   #5
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
Quote: Originally Posted by AyrtonSennaD
thanks guys
-zip-
thanks
For the same reason as you, I went with a slimeline normal Atx case. Slim PCI NVidia video card. I also like the fact you can configure a larger case for heating and cooling. With a slimline ATX case in the summer I put 4 large fans inside the case, before I did that it would overheat, dunno how these little cases can hold up to 30-40 degree temps.
Parts are another matter, some you need to buy in the US. Powersupply and perhaps LCD screen. The rest are available in Canada.
Carputer
Sound Stage
Sponsored Links
vB code is On
Trackbacks are Off
VIA motherboard and PCI USB card warnockm General Hardware Discussion 4 10-16-2005 03:59 PM
Trust 5.1 External USB Sound Card 510EX, any good? FociMan General Hardware Discussion 0 06-26-2005 05:16 PM
The "Official" low profile card post lakorai General Hardware Discussion 8 05-22-2005 08:49 PM
5.6" LCD, PCI TV/Radio, 7.1 sound card, Sony amp & more eatyummypuppies Classified Archive 22 06-29-2004 07:19 PM
USB external sound card? fondoo General Hardware Discussion 9 05-24-2004 02:32 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
